Atlas timing cover screws
I have a 1965 Atlas Engine No.111367/P . The timing cover screws are 6pcs 1/4"whit x 1" and 5pcs are 1/4" whit x 11/8" and one more screw is 1/4" whit x 11/4".
Haynes manual states 6 should be 1/4"whit x 1" and 6 should be 11/4" plus a drg showing their location.
Similarly Andover Norton appear to list two sizes as above.
Could someone please advise why my engine should be different.In this case I am referring to allen bolts which also have a fibre washer behind I think.
Previously philip_hannam wrote:
Somebody's Haynes Manual must be different to mine.
Page 38 of my Haynes shows Timing screws sizes and positions.
See attachment
Thanks Philip for the info it all makes sense now !!!
See attachment
Correct, I couldn't find this picture in my Haynes Featherbed manual. It seems to be only in the Commando manual.
Fritz
See attachment
Fritz
Hello I have found the Hayens manuals to be in correct on some subjects the wiring diagrams are incorrect years for 650 manxman and 650ss
Further,-the Electra primary drive cover has at least three different lengths, on one occasion working on a customers bike I found the holes in the primary case iner of different lengths to my own Electra, I had a spare engine, checked that-different again. so it appears that you get what you get at time from the factory.
I do not like Allen bolts for this job in any case, after having them for some years we find that often the Allen screw is SS and hence too hard for the ally it is going into, and being a socket head very easy to over tighten also it is very easy to have a set of cover screws that are just notthe right length, so you end up stripping out the ally thread in the chain case. I find that going back to the traditional cheese heads you get the right lengths and as your screw driver might slip out of the slot when you tighten you take extra care when tightening and do not overtighten. You pays your money and takes your choice.
I'm with Al regarding Allen head cap screws. The cheese head are both original and safer. The other way of ruining threads is to forget to clean out the threaded holes from time to time. I have seen a few damaged cases caused by partially blocked threaded holes and enthusiastic use of Allen screws.
