Mk.2a belt conversion alignment trouble
I am having real trouble fitting a belt drive from RGM. The shafts just will not align. I have the RGM double adjuster and I have tried pulling the gearbox back with the left hand one. but it is still not parallel and the belt tends to walk off the pulleys toward the outside. I have tried forcing the box to rotate with the use of both side adjusters, but predictably it all binds up rather quickly. Is there anything else I can try, or should I box it up and send it back and go back to the chain?
Would be prudent to check the condition of your sleeve gear bushes, as any movement there, no matter how small,can exacerbate (good word, no?) the problem.....
Hello Rupert.... Remember the old steam fairs when a stationary steam engine powered a threshing machine with a long leather belt ??The pulleys were barrel shaped and the belt always found the highest point on the barrel. Can you visualise what I mean ? The way you are adjusting your belt could be the opposite of what is required.By adjusting the gearbox the opposite way would make the belt find the inside of the clutch drum pulley.Give it a try and let me know if it works !!!colin
Aha! The reason I decided to fit the belt was that I suffered a catastophic failure of the layshaft bearing. I thought that whilst apart I would bung on the belt. I replaced the casing, all the bearings and all the bushes, exceptthe sleeve gear ones, because the looked too hard to do. Ho hum, looks like its all coming apart again to do the bushes. Any advice on pushing out the old ones and the new ones in?
I liked the post about the old staionary engines... I will give it a go if the bushes thing doesn't work, I might even try a half twist in the belt and see if that helps. Haha.
Thanks again all. I will let you know when its done.
Rupert
Rupert
Not overly sure if the Mk2a sleeve gear is the same as the Mk3 but....
To remove mine (engineers look away now!)... having had a great time prising out the internal circlips... I split the bush with a wood chisel enough to get purchase with a pair of pliers (the chisel isn't hard enough to damage the gear itself) Then used the new bush to push the other old one out, then used THAT (old)one to drift the second new one in. BUT, used a piece of wood to 'persuade' them in, not a hammer!
As many have mentioned, belts don't have to be overly tight to work.
PS: On a 20,000 mile bike my mainshaft needed renewing too, ridges where the bushes 'supported' it....... not!
Rupert
Hmmm thanks; maybe not my best wood chisels, but here goes.
Thanks again
Rupert
It does sound like you are adjusting the gearbox the wrong way. Before you start knocking the sleeve gear bushes out with wood chisels and the like, try slackening the left adjuster and tightening the right one whilst maintaining the correct tension as per the RGM instuctions. If the belt still creeps to the outside of the clutch do it some more until it stops. Jim
The way I align my sprockets is to use two 12" rulers. If you put one each on the outside face of the two sprockets and then overlap the two rulers between the sprockets you can see pretty clearly if they are in line. The belt may still run off slightly due to play in bearings but it's a good starting point before fiddling a bit if needed.
Ian
That's what I suggested !!!
All
Thanks for the input, I have gone back to the chain, it appears that there is rather too much play in the clutch bearing for it ever to align, especially under load. I am thinking the advantages of the belt are outweighed by the risk of it self destructing against the guides. There is zero movement in the sleeve bush, so I didn't change it.
I was adjusting it the correct way and I tried it without the adjuster on the right, as well as using the RHS adjuster to "pivot" on to force the clutch gearbox to rotate, but there is not enough leeway between the engine plates, causing it to bind before the pulleys line up.
One thing I wondered about, was reversing the top gearbox bolt. The threaded end has very little movement, so it might be better going the other way. However, its all back together now and I want to ride it again. The other thing I noticed was the inner chain case fouls the new adjuster on the left. I will have to releive it with a dremmel or something.
Rupert
