s+b filter
I have been running my mk3 with bellmouths fitted(odd ones so they fit),just fitted a s+b one piece and it run crap,will I need to re jet ? if so any tips on size etc.
ta Pete
Logic indicates that you will have to downjet. Just keep going down in size until it runs correctly.
What jetting and slides are you running at the moment ? Small individual or double filters with a back face close to the carb don't really seem to suit Commandos and make the carbs difficult to tune.
I found that slides with a larger cutaway helped to disguise the lower-mid flatspot but never got rid of it completely.
Do you have 850 cutaway spray tubes with the long needles ? Although fine with the big airbox, They will complicate things too.
