I remember Curley as makin…
Greetings Reg Curley (RIP)…
Greetings Reg Curley (RIP) did a lot of racing development work and also had a 'special' cam ground. His 750's were very quick and were fitted (if I remember correctly) with a Weber 40 DCOE carburetor. Pretty sure Dave Croxford used his set up as did Brian Kemp. Otherwise I have no further information; believe his family still run the glass business, so maybe an approach from Roadholder to the family for an article / history record would be appropriate before all this information vanishes?
Rgds
Steve
Hi. Thank for the info, wa…
Hi. Thank for the info, was just courious as has not seem before. I will try load up a picture of the casings
His brother worked for Pau…
His brother worked for Paul Dunstall as a mechanic and was featured in a 1960's magazine Motorcycle Mechanics.
It's a wide line frame wi…
It's a wide line frame with the commando engine, the head stock is stamped with the same number as engine, NC3000001
I remember Curley as making copy JPN fibreglass.
A Google search indicates that they made glasswork for Dunstall and ran a race team.
Curley GRP Ltd.
