My question is, would a clutch actuator lever from a dommi/atlas make my clutch easier to pull in.
Please no essays on clutch stack height. All my plates are good size.
Tried another plain plate & it just made the clutch slip.
According to David Comeau,…
Previously Colin Peterson…
Previously Colin Peterson wrote:
According to David Comeau, yes â scroll down to the heading 'Atlas Actuator', past the essay on stack heights ...
http://atlanticgreen.com/ndnsclutch.htm
ButI haven't tried it.
The stack height is the key an as much has been written about it as isolastic clearance. But as with both get them right and the bike will be a joy to ride.
Previously gary_knowles wr…
Hi Gary
I have been up and down the stack height thing on my Mk3 and as you say an extra 2mm steel plate also made mine slip during spirited riding. I had a better result replacing one of the standard 2mm steel plates with a 3mm steel from RGM it improved the heavy lever situation with out any slip. I went on to make a hydraulic conversion for the final step.
Katherine
The actuator lever inside…
The actuator lever inside the box does benefit from a liitle re profiling with a oilstone to remove the sharp bump.
Previously robert_tuck wro…
Or you can trim it with a dremel to the profile as stated by David Comeau here on the drawing attached.
Fritz
Attachments clutch-lever-jpg- Log in to post comments
I have a Dommie/Atlas leve…
I have a Dommie/Atlas lever in my Commando. In my opinion it doesn't make the clutch lighter, but removes that 'over center' feeling with the standard set up. it's worth doing.
The over centre bit is the…
The over centre bit is the diaphragm spring working as it should
