Looking for a set of correct Fastback badges
Looking for a set of correct Fastback badges, but here's the rub, what is correct?
dsc05730-jpg
we made mine some good few years ago as they were not available, the earliest ones were just an orange blob were they not did this ever go onto production bikes? they are now available from Norvil also. kind regards
Hello James
I think this depends on how much you are trying to match the original.
It is worth looking at this link (& search for others) on Access Norton http://www.accessnorton.com/commando-tank-badges-t19304.html
I have checked an original parts list and can confirm that the tank and tail-section badges have different part numbers 06.0864 for tail and 06.0499 for the tank. 06.0500 is listed as the adhesive for both.
The Access Norton thread indicates that the original tail-section badge was flat-backed whereas the tank badge is round in profile (presumably due to the rounded tank). I'm sure there are ways to adapt the new badges.
RGM also supply one made by Wassell.
Hope this helps
Andy
I am looking for the type that has the metallic backing that shows through the clear plastic as achrome like reflective finish. Used is OK too. See my above attached photo.
