tank transfers
Hi , silly question time perhaps, I have my f/back long range tank back,painted and polished, there are of course no recesses for the circular tank badges so script transfers I assume are used, however can some one perhaps explain exactly where these were appended [within reason of course human error etc] or maybe a pic of them on a tank ?, kind regards
Take a look on this website under the Models section.
There is a side on view of a red Fastback LR which clearly shows the position of the transfers. The circular recesses you refer to were used on the early composite material Fastback tanks but not on the steel petrol tank Commandos.
There is a difference even in the two models shown on the LR photo. The bright red one looks better with the decal half way between the ridge and the bottom of the tank IMHO. Consider temporarily positioning the decals with blue tac until you are happy then, using a strip of masking tape, put a datum line under the final position before fixing.
