Are there any recommendations for local mechanics in midsomer Norton mobile wise ?
Rob, You may wish to…
Rob,
You may wish to consider joining the NOC Bristol Branch which is just down the road from you. They have a wealth of knowledge regarding Norton singles and members living in and not far from Midsommer Norton.
I think I can join Bristol …
I think I can join Bristol . I have got it running but there is oil. In piston area that kills spark . It will run for around 5 miles then spark is covered. I need someone with more knowledge as I haven't got a clue. If it's exuberant pressure or a dodge ring and I don't I will ask to join Bristol group now sorry about that bad spelling
Hmmm my first thought is…
Hmmm my first thought is cracked or broken oil scraper ring on the piston
Hi there
I'm based in Portishead so not that far what is the issue you are having as I may be able to help.
cheers Matt
