Recommend
Are there any recommendations for local mechanics in midsomer Norton mobile wise ?
Hi there
I'm based in Portishead so not that far what is the issue you are having as I may be able to help.
cheers Matt
Rob,
You may wish to consider joining the NOC Bristol Branch which is just down the road from you. They have a wealth of knowledge regarding Norton singles and members living in and not far from Midsommer Norton.
I think I can join Bristol . I have got it running but there is oil. In piston area  that kills spark . It will run for around  5 miles then spark is covered. I need someone with more knowledge as I haven't got a clue. If it's exuberant pressure  or a dodge ring and I don't  I will ask to join Bristol group now sorry about that bad spelling
