Hi does anyone happen to know what size tool is required to adjust the tappet? Is it 5/16
Thx
0.44 " ( 11.3 ) mm …
Sorry this tappet which has…
Sorry this tappet which has a square end.
And to do the tappets (job for over easter) assume I just need 4 gaskets?
I made a little tool....
... for a Triumph twin which uses a similar method. A short length of 1/2" diameter alloy rod drilled centrally (about 6mm IIRC) then a tapered square section drift hammered into it. Then knurled to make it look posh.
Actually just realised it was for a Honda but the same applies.
Here it is:
Assume it simply needs…
Assume it simply needs something to hold it still while the nut locks it up right?
I use a brass radiator bleed…
I use a brass radiator bleed valve tool, fits perfectly
A bleeding good tip that !…
A bleeding good tip that !. Something new always.
For ref the c spanner ref on…
For ref the c spanner ref on Andover Norton is 06.4018 :)
0.44 " ( 11.3 ) mm
