In the 1961-62 parts list in the centre stand section on page 43 I've found the items «17591 Rubber stop» and «E5278 Pin for stop».
Somebody outthere knows those items?
Fritz
Bump stops for stand to…
Thank you Ronald.Can you…
Thank you Ronald.
Can you tell me how and where it should be fitted?
Fritz
Bump stops
Just down from the pivot there is an "ear" each side. The left hand side ear should be drilled to accept a bump stop.
Thank you Ronald. Should…
Thank you Ronald. Should mount an overall and gloves to investigate.
Slimline Centre Stand
I used an old footrest rubber, sliced along the longitudinal axis (whoo, get me!) and fixed to the stand 'cross bar' with tape. Works for me ;-)
Kevin
Bump stops for stand to protect frame?. Pin? dont know.
