Hi
I am working on a 57â 19S and probably want to replace the dust cover on the rear hub as it is rather dented
It is held on by rivets, I know later they switched to screws
Any advice on removing and replacing the rivets?
How are they attached inside the hub?
Where could I get the right peening tool?
Thanks, Mark
Previously mark_eakins wro…
Mark, What Alan says is sp…
Mark,
What Alan says is spot on. I bought a new polished cover complete with a set of stainless self tappers and three rubber grommets from RGM.
Gently grind the top off the rivet and use a very fine drill. (Smaller diameter than the widest part of the self tapper) Or you could simply drill through the rivets as Alan suggests. I found the metal just about soft enough for the self tapper to secure the screws. Keep checking to ensure the holes line up.
That's about all there is to it. You don't need much of a hole.
I hope your machine is complete as these models are not well supported for spares, where they differ from F/bed models.
Let us know how you are getting on.
Hi Alan and Neil As far as…
Hi Alan and Neil
As far as completeness and how it is going, some plus and minuses
The last tab on the license plate was for 1970
The person I bought it from said his dad bought it for a âbondingâ project with his kids
The positives are that the tank, tool box, oil tank, wheels are there and in pretty good shape
Nothing is really rusty, it was in a garage for over 40 years
The bad is that somewhere along the way someone decided to make it sportier looking (my guess)
They cut off the rear fender, replaced the front and filled the holes in the gas tank
So I donât have a whole rear fender
And the other bad is the terrible âworkâ on it, the wrong threaded studs forced in, terrible weld repairs, things like that
The timing cover is there but had holes drilled into it and filled with epoxy or something
There is a terrible repair to the frame near the brake pivot and to the pivot itself
There is an expert frame repair place near here but it would be too much, so will have to look elsewhere
I will post a wanted ad for a few parts in a bit
I live near Seattle WA, US
Here is a picture of the frame
Thanks Mark for introducin…
Thanks Mark for introducing me to the most interesting Norton forum I didn't know existed.
Personally I would replace…
Personally I would replace the rivets with rivets for originality. Self tapper would not look right. They are probably simply round headed rivets with a spiral shank. They may even turn themselves out of a left handed drill were used. (never tried)
Previously mark_eakins wrote:
Hi
Thanks, Mark
Those are not really rivets. They have curbs on it. Something like this: http://www.norvilmotorcycle.co.uk/061287.htm
I've slotted the head with a Dremel, not to deep, so it can be turned out like a screw, sometimes.
Fritz
Mark, I could tell you wer…
Mark, I could tell you were from stateside, you say Fender and I think guitars! Alan in NZ confirmed to me that apart from a couple of holes, your rear mudguard (Fender, hee hee) is the same as a wideline. That should be good news but the club has no more stock and it might take 100 years before they get any! I was being serious...discuss!
If push comes to shove, Fred Williams can always make you a front mudguard.
I was pleased to see you have the attachment that links up the swinging arm and the rear of the engine plates, over the gearbox. Skip B managed to secure me one of those on US Fleebay and I have never seen one for sale since. I have the earlier one if anyone needs it. (56 and before, screws on both sides of the swinging arm)
I didn't see the rear tank mount but that can be made if you don't have one. You can buy the cups and rubbers from Norvil.
Undoing bodges (Sorry, temporary repairs) is to be expected but just take it one bit at a time. Thanks for the update.
sometimes I say mudguards…
sometimes I say mudguards for my UK friends, and wing and bonnet...
I bought a couple parts from Skip, he has the wideline fender and it looks fine, I would be happy IF I could get that
There was a rear tank support on the frame, it looked homemade, I bought a new one, still available, but I have not tried it on yet
There is a guy in my state that had what I think is the earlier single down tube frame for sale if someone is interested
I have not tried a photo yet, if this works it is the way the bike looked when I got it
I had Andrew remake the seat and it looks great, first part completed!
dsc_0001-2-jpg
Thanks for the photo Mark,…
Thanks for the photo Mark, paints a thousand words.
A headlamp shell might be difficult to find and the chrome tank side panels. But if the holes in the side of the tank have been filled in and smoothed over it may be as well to leave it as it is and put a transfer on the tank.
The good news is that you can still buy a new exhaust system and there doesn't appear anything missing to keep you getting the bike on the road. That would be my initial target.
PS: if you don't find an original headlamp shell you can always mount the Speedo on a bracket until you do.
I have a headlight, speedo…
I have a headlight, speedo, tail-light housing and a repo chain guard from a guy in Canada
I also did get a set of chrome panels, which I feel extremely lucky to have, even though one is in rough condition
I was thinking I would have to do the tank in 56â style
I have all the paint off the tank and it looks like all 8 fastener holes are in good shape
I am having difficulty getting the exhaust though
I have the front part of the rear fender but it has been cut
I bought a set of repo fenders from India, they are not at all right, but I might try and have someone make one that looks right using the crown portion
The most depressing thing right now, someone drilled a hole in the timing cover where oil pump outlet was and then filled it with putty, trying to figure out how to fix that
Maybe I can find a 'new' timing cover
And someone welded the exhaust nut on!
timing-cover-repair-area-jpg
Good Luck, the rivets are hardened and the only way is to carefully drill them with a sharpdrill, asmy replacement hub cover cam with screws I used them though a little ali welding was required where I went off the rivet. Be aware that the 57/58 M50, ES2 & 19S are different to earlier and later models. Neil Wyatt who is regularly on this forum and my self have already been down this road with this model year and hopefully may be of help to you though as I amin NewZealand I am a little way away.
Alan
