          Help!
I need good technical advice regarding which type of oversize (+20) I should use. The pistons presently fitted are of the long skirt type,make unknown,and weigh 302 grams.I have obtained a new pair, made by JP, however, these weigh 370 grams and have short skirts.As my engine has the older type crankshaft and the alloy capped con-rods,I am concerned that the balance will be wrong and excessive loads will be placed on the bottom end.
Any suggestions ?
Terry
You are absolutely right t…
You are absolutely right to be concerned about the weight difference. Many of the replacement pistons, on the market, are much heavier than the originals. JP & GPM most notably. Lots of owners have fitted new pistons without checking and ended up with teeth rattling vibes. A few extra grams are not going to be a problem but adding nearly 70g on for each piston is around a 25% change. Probably requiring a crankshaft rebalance.
Checkout the other recent Heavy Twins thread about pistons. There is lots of good advice within it.
