Tyres Dunlop TT100
Simple question? what pressure should i set these to. I have been following the manual over the years but the tyre shops says they should be at 30psi. Have i been wrong for some time?
The last time that I was running TT100s, I was using 27 /30 or 29/32 if fully loaded. Normal practice is to run the front slightly lower.
Always used psi 24 for front and 26 for rear with TT100 tyre on two Commandos I've owned - handling excellent.
thanks for the replies will experiment and see what happens.
