000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Amal carb 276 on 1936 16h
I have a top feed carb with a new float and needle however it doesn’t seem to stop the flow of fuel! any suggestions or if someone in Surrey can be recommended to take it to?
Mark...have you trued twisting it round a little on the spigot to lower the float chamber a little? (I've not met a top feed float chamber...76 and 276 are usually bottom feed)
then the needle is not seating.  I would get some engineer's blue and see what the seat looks like.  Anyway, if it's not sealing, put a little fine grinding paste on the needle taper, grind LIGHTLY, and then clean everything VERY CAREFULLY.  You don't want to leave any grinding paste in there.
Privacy Policy
