000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Timing cover screw lengths
Changed these for cheeseheads from allen sockets have fitted 6x1” long from 12 o’clock to 3 o’clock, remaining 6 are 1 1/4”, they all pull the case up tight. I haven’t committed a crime any where with longer bolts like blocking an oil drilling?
cheers
I measured out all screws and arrived at 6 x1” and 6 x1 1/4”, these are very nice machined screws with slight filister head from RGM
At the risk of teaching you to suck eggs. Put the cover back in position and then use some form of depth gauge to confirm where the respective length screws should go. The drawing is not too helpful with a set of two-length screws.
On the subject of cover screw lengths, I once tried to replace the primary cover screws on an Electra which normally has 2 lengths with one extra long.. Couldn't get screws in so measured the hole depth in two other cases-2 versions. Spoke to Andy Soch. got a third length! so the actual hole depth between engines can vary! Turned out the first case had its holes bunged up with red Hermatite!
On the subject -although socket heads look nice they can easily be over tightened. So going back to Cheesheads made one a little more careful when tightening them to save scratching the case. Also one assumes that the original cheesheads were the correct length.
What i do is tighten each screw individually and watch it squeeze out the gasket grease found before just checking the depth doesn’t always check the full depth of the tapping
Privacy Policy
