73 850 Commando Misfiring badly
Hi People,
Since buying my 73 Mk1 850 Commando I have not managed to get more than 500 yards without it misfiring so badly that I have to limp home.
It has Boyer Electronic Ignition.
First fire up from cold it is fine. Starts easily and ticks over at 500-750 rpm.
When warmed up as you move off it misfires splutters and backfires. I only made about 30 yards this morning!
Tried so far....
1st suspect was the coils. Both 6v which is good. Clamps had squeezed them badly and prime suspect was internal coil hitting the casing when warm and shorting.
Just fitted a new pair of Lucas 6V coils. Just nipped them up. Insulating tape to isolate casing from clamp. Absolutely no change. Just as bad
I rechecked the Boyer wiring and all seems to be in the right connection order (although didn't pull the tank and check it 100%) and I tend to think that electronic ignition either works or its dead.
Where next people?
Ignition timing? Carb?- but if you rev when its cold it seems fine. Something else in the wiring circuit that breaks down when it gets warm
All the best
Eddie
I had similar but not as debilitating you could still ride long distances then it would misfire or stop altogether. Long story short was due entirely to the big rubber leccy bullet connector breaking up inside (45 yrs old had bike since new) the one that connects the main harness to the handlebar switches under the tank 850 MK2 us export roadster. Best of luck worth a try and costs next to nothing !!
PS malady was there for a few years but very intermittent went back to coils and old points for a while and was ok. Boyer did not like it cause it was the white power wire from the ignition switch that suffered worst.
Also all leccy equipment works like new now.
Bill D
Choke cable. Was not fully open so tightened the cable lever. It was only down by about 1/4" so don't think it is the cause but good to eliminate.
Removed the side cover for the Boyer trigger. No obvious breaks in wiring or connections. Wires are very close to the outer casing so maybe worth pulling out and putting more shielding round them.
Thanks for the tip on the main harness. It could fit the symptoms.
Eddie
Start the bike and while it is ticking over steadily-warmed up. Wiggle the pick up wires at the pickup, any issues the bike will stop instantly. When trying to drive, switch the lights on-any change? disconnect the rect/reg or rectifier output, (ride bike on battery) any change? Disconnect the H/Bar kill switch (under the tank)........continue with carbs......report back.
Hello Eddie, I would very carefully check the wires in the Boyer stator (in the points housing) - it's not uncommon for them to break-down inside the insulation or where they are soldered to the stator (on the rear). Before you remove the stator to check them, mark the stator position (felt-tip pen or similar) such that you retain the (presumably correct) ignition timing. These wire faults are well known for causing mis-firing etc.
Thanks. Will work through these.
Also. I pulled the headlight cover to add some Waxoyl and WD40 to keep the shell from rusting. The leads to the bullet connectors literally fell out after spraying with WD40. I got the pliers on them but maybe I need to recheck every connection is good...although there's only the ignition light in the ignition circuit. Worth doing anyway. I bought some spare bullet connectors from the club site.
Wiggled wires on pickup. No change.
I think it's tank off, pickup off and work through all ignition wiring connections.
I noticed that the bullet connector to the rear lights by the battery looked corroded so maybe there's one similar lurking. Harness under the tank to the earth connection is very tight so there is definitely room for improvement.
I'll maybe pull the ignition switch rubber boot and check there too.
All suggestions very welcome.
At the moment the '69 Triumph Trophy is winning the reliability battle and that can't be right!
Eddie
I had a Boyer fitted Commando that would only run badly with one cylinder cutting in and out, changed Boyer boxes, rotors. coils HT leads etc none of which worked. What did work was running a dedicated earth wire from head to battery positive terminal. Also Boyers can suffer from the feed voltage being too low which can be caused by an iffy kill switch on the handlebars and also a bad earth, so I run the Boyer earth to the same bolt on the head the dedicated engine earth from head to battery.
The very common 'sticky tape' syndrome. The lump that has the WHT/PPL wire is very suspect as this is ignition!! Sticky tape is to be avoided at all costs, it eventually comes unstuck and just hides a hoast of ailments/bodges.
The RED crimps used on the other side are to be avoided, they look horrible and unless fitted with a decent ratchet crimp tool are subject to falling off, but the coils look well fitted. Although the insulation is not needed on new coils. If such insulation is needed then the coils need to be replaced as they are shorting to earth inside.
The item above about the pickup is true but I doubt a problem in this case as the bike starts fine. Taking the cover off  and wiggling the wires will soon show up a problem if there is one. The idea about the Earth from cylinder head back to frame/battery is worth examining.
I had a similar fault, blamed the Trispark ignition, changed it to Pazon, no change eventually found it was the ignition switch where the push on connection had come loose, causing a intermittent connection.
I do like these threads but they are hard to answer with limited understanding of the symptoms. When does the misfiring and popping start, all the time or after a bit of a run? Does it misfire at all revs?
Could be fuel starvation, low float heights, blocked fuel tap filters or tank cap breather blocked.
Have you tried replacing the spark plugs? Check HT lead connections for corrosion at the contact points.
Also worth checking contacts at the kill switch. Bypass the switch to see if it makes any difference.
I would also run an extra earth from the cylinder head steady to one of the nuts on the coil mount bracket.
On a separate note, I have recently fitted an oil pressure switch to mine and have been monitoring oil pressures. Oil pressure can be surprisingly low at tick over when the oil is hot. In my opinion, 500 rpm is too low and an idle nearer 1000 is better for the engine.
Please keep us up to date with your findings!
Steve
Read somewhere that the 2MC cap has to be mounted vertically. Used to think it was to keep water out, but  apparently not so.
checked and re-wrapped some of the wires. One of the wires to the coil pulled out of the terminal so glad I found that. No obvious smoking gun. Refitted the tank. Started fine then ran worse and worse. Lots of misfiring.
Changed to new plugs - Had a couple for the Triumph. Not the correct grade so ordered a new set. Ran perfectly. All issues cured.
I'll wait for the new plugs then give it a good run. I've heard that new plugs can be a temporary fix for ignition problems so not sure this is solved.
Thanks for the brilliant wiring diagram. Much better than the factory one
Not checked and next in line is checking the ignition switch terminals and also bypassing the ignition kill switch. Good idea to run an extra earth. I'll put it on my list. With new plugs it idles at around 1000+ and sounds better for it. Good tip on oiling.
Yes. Definately a bit of a mess under the tank wiring wise. I'll put that on my list too.
Eddie
Couple of thoughts and q's for anyone still following this thread.
1st - big thanks for all the advice. Lots of sound tips and pointers that I'll be following up.
First off,
Alan- Urgh! Great point. The main loom looks rubbish. This would be my plan...
I would like to strip it out, unwrap it, remove all redundant wires, inspect, test, rewrap (have non sticky loom tape to keep Alan happy) and refit. Anything to watch for? Can I leave the rear loom in situs?   Question mark on the multiple bullet connector under the tank- can you get replacements if its stuffed or use separate bullets- but where does that leave the 1x White to 4x White?
It will also allow me to wrap additional earthing wires exactly where required as suggested by John and Steve and keep it all neatly in the harness + get the wires where they need to be to connect with the Boyer.
Any thoughts on this?
Alternatively...New looms aren't expensive but I'll have the same issue of redundant wires being taped off + I want to run extra earths + it won't fit the Boyer without adapting
2nd is the re-check of Boyer as per link. It's really thorough. Be a good time to check the ignition timing too plus the connections are a bit iffy. Link suggests leaving slack in lead to points housing for the engine to move on the isolastics which is sensible.
3rd is wiring and seeing if I can pinpoint a fault. I have tips from you guys on earthling, engine kill bypass, large bullet connector and ignition switch so can focus on those.
Thanks again
Eddie
I have had an old harness suddenly develop internal breaks inside the wrapping, impossible to find and even if fixed when is the next break going to happen. If you are going to unwrap and remove the redundant Interpol wires and those made redundant by the Boyer I would either start with a new harness or buy a DIY harness kit off Alan Osborn and make a bespoke one.
http://www.aoservices.co.uk/info/WIRING_KIT.pdf
...or get a specialist to make one for you.  The old stuff will only let you down further down the line.
My commando threw the battery in the air on a certain island and shorted the neg out to the  frame. Front loom replaced with off the shelf replacement; nothing but trouble with the rear after that so did a bit of  web searching and was fortunate to find a local company that makes looms up for industrial/automotive/aero use, they were very obliging, kitted to do the right job with right tools/components and not expensive.
 Alternatively get Alan to make one up for you...
J
But, have you made sure that the carbs don't have any water in the floatbowls, blocked passages etc, etc? - I do know that my Morini is a bugger for low speed misfires if any water gets in the floatbowls. Blocked passages or jets might make it run too weak 'just off idle' and cause the misfires too.
Remember the old phrase, if it seems like an ignition problem it is the carbs, and if it seems like a fuel problem, it is the ignition!
Looking at the pictures you have posted however, I agree it does look like an electrical issue you have,
As regards a new loom,  I find it quite therapeutic doing the wiring. Just make sure that you plan for any 'upgrades', like modern voltage regulator, front brake light switch (if not fitted), better fusebox with each circuit having its own fuse, 'better' switchgear etc before you start. otherwise you will tearing it apart soon after to put the extra wires in/blank wires off.
Al O's wiring kits get a good write up from members as being good quality and value. A decent pair of crimping pliers need not cost a fortune either. If it were mine, I would do all the wiring in one go as that will eliminate any questions about its integrity.
Keep going - You'll get there.
George.
Excellent link to creating a new loom. Many thanks. I didn't consider that.
Very little time this week for garage stuff but plenty to think about.
Just a thought...about the engine kill switch- why not fit a small relay next to the Boyer so you have current direct to it from the ignition switch as the default and somehow switched off by the kill switch? Would that work?
Eddie
Reading through this post I kept saying to myself, stop messing with this old wiring-rewire-my kit. Then all you chaps sell it for me!! Seriously the effort to strip off all the old tape and uncover the wires and attempt to reconnect every thing is just not worth it. In fact take note all, old wiring on British bikes (and cars) when you came to reconnect you find the copper under the insulation is going black-BLACK DEATH it is called. You will not make any decent connections to this tarnishing. IF you are stuck on the road with this problem and trying to remake a connection then scraping the wire with your trusty Swiss Army should do the trick. But please consider rewiring properly as soon as you can.
The idea of a small relay for the engine kill? Yes it would work but you are introducing another load of connections and contacts with the relay, something else to fail in the ignition circuit. Why do you need an ignition kill anyway?
From George-'Remember the old phrase, if it seems like an ignition problem it is the carbs, and if it seems like a fuel problem, it is the ignition! ' Exactly, after 55 yrs of fixing engines etc I still have to remind myself.
It sounds like the spark plugs were the main culprit and if it runs OK now I would say get some miles under your belt so you can enjoy the bike and discover if anything else is not quite right THEN RENEW THE WIRING!
There are various sources for new looms (all have unneccessary wires) but I'm just in the middle of re-wiring mine from scratch using AO Services superb kit and a huge amount of sensible advice from Grant Tiller (check his website). It's not as scary as you might think but you do need time and some decent crimp tools. Personally, I've found Vehicle Wiring Products MP71 and D1 tools very good for 'spade' terminals (Al O calls these 'Luca' terminals) and do get the essential 0400 Closing tool for bullets.
I had big problems with solder bullets (intermittant dry joints = terrible misfire) and personally would avoid these. I prefer hex crimps for the bullets and Auto Sparks sell a superb AST1 tool (not cheap but well worth it). AO provides W crimp bullets as an alternative and the MP71 & D1 will do these. Leave some extra length of wire (safely) where you can so that you can upgrade other things later if you decide e.g. ditch the Zener diode + rectifier and go for 1 box regulator/rectifier.
A quick word on that kill switch: yes it's nice to have one but this is the only "press to break" switch on the bike and it relies on a relatively weak spring contact to maintain feed to your ignition. The good news is that if you DO experience problems it's relatively easy to disconnect the white feed into the h/bar switch and feed it directly to the Boyer (or whatever ignition unit you have by then).
But the main thing is keep going Eddie because once you have sorted it out, the Commando is a wonderful bike that makes you grin every time you use it. I've covered thousands of miles on mine riding all over Europe and NOC rallies are great fun.
Jeremy,
I guess it was 74 or 75 when I saw a big yellow 850 Commando Interstate in the window of RO Clarkes in Ber Street, Norwich. That image stayed with me and so nice to to finally get your hands on something you dreamed of as a kid.
Eddie
New plugs seemed to have cured it. Old ones were sooty but didn't bother to clean them. Reset the idle mixture a tad leaner. Took it out for a quick spin and top up with petrol. Restarted 1st kick at the garage which inspired confidence as balancing it upright while kicking is a bit tricky for me.
Couple of spare new plugs tucked in the side panel just in case.
Loom is on the suspect list so will probably swap out in the winter+ + extra earth suggestions. Excellent price in the spares shop so no excuse.
Looking forward to the summer.
Eddie
In reply to by eddie_cross
Just to say
Its been over a month and has not missed a beat since I swapped in new plugs.
Starts 1st kick every time from cold or hot. I reset the idle mixture a tad leaner on the Amals using my old trusty Colortune.
After starting I whip off the choke as quickly as possible to keep sooting up to a minimum. Plug colour coming out just right after a run.
Zero issues with the Boyer. Rechecked all connections. Recrimped a couple plus shrink wrap around connections in the points cover as could have been some shorting. On my crimp tool I jamb some paper or cable wrap in the jaws so it crimps extra tight.
My 1st Commando and absolutely love it.
Eddie
