          I have a 1963 Electra with a healthy oil leak at the kick start shaft. The exploded view of the gearbox in my parts manual doesn't show anything resembling an oil seal.
Any suggestions on how I stop this leak?
Thanks.
Square section seal
Kickstart oil leak
Can these O-rings be replaced without removing the gearbox?
You have to take the gearbox…
You have to take the gearbox cover off but the gears are not affected..
The square section seal from the NOC shop worked for me. The square section option is not the standard round section O-ring but works better. Fit it on the gear lever as well. You have to take care not to damage it when re-fitting the cover.
