part numbers for rare norton manxman 650s
Hello now recommissioning New  hard to find  parts for the Norton Manxman 650 maybe  a non starter for this club  As I do not think that the club as the very rare USA issue by bracebridge street For the  Norton manxman 650 parts manual for  start  So no one on the technical team will be able to verify   these parts in the first place  As you have no parts numbers as there not in the 1961/2 Norton 650 Model 88/99 and lightweights  parts manual as I have copy of the USA Norton Manxman parts manual  And you find that not all part number are the same for the 650 as for the Manxman 650    exhaust system has its own part numbers exhaust pipes are part numbers 23432LH and 23433RH and exhaust silencer are part numbers 23174RH and 23437LH   and the small manxman tank as it own parts number 23325  along with the seat part  number 23336 and inlet rocker cover breather  parts washers are T2084 -T1084-T2088 . banjo assembly parts number 23478. sleeve for banjo 23427 rear inlet cap stud part number 23426  and Manxman pistons are part numbers   23268LH and 23269RH   Now the Manxman handlebars Are part number 22460. Now thats just some part numbers  you may not have   Now I hope this may help  So do not delete this part numbers Mr Smith webmaster                      Yours  Anna J
