Could anyone tell me if a 1960 dominator 88 should have a high or low pressure pipe to feed the rocker shaft
Ian
88 & 88SS Models
The factory fitted high pressure rocker feed arrived in 1966 just as production of the 88SS was finishing. I am therefore fairly certain that none of the versions of the 88 (standard, d/l or SS) ever had a pressurised rocker feed, conrods with oil spray holes or 6 start oil-pump.
LOW.
