Hi all,
I have a charging issue on my '72 Roadster.
It has a new Boyer Powerbox fitted a few thousand miles ok and has run fine until now.
WIth lights on its showing 11.4v at the battery.
I just tried the bulb test across the alternator output wires and it lights up fine - the resistance across those two wires with the engine not running is 0.4 ohms.
I've just swapped the Powerbox for another new item - same results.
Any ideas please?
Regards - Paul.
How old's the battery?
Hi Paul, Has anything else…
Hi Paul,
Has anything else changed coincidentally with this situation? have you had the tank off, changed the handlebars, been poking around in the headlamp? sounds like a simple wiring fault to me.
Do you still have your original rectifier and zener diode? might be worth re-fitting them and seeing what transpires. You should get 13 to 14v across the battery at about 2500rpm
I've swapped out the batt…
I've swapped out the battery - I had a different style of reg/rec fitted from Paul Geoff for several years, prior to switching to the Boyer PowerBox, so the original rectifier and ZD are long gone.
Regards - Paul.
Check the stator output. I…
Check the stator output. I think you should be getting approx. 15 volts AC when revved, across any two wires. Also check your earth connections.
I recently had a similar p…
I recently had a similar problem after replacing the primary on my bike. The alternator output measured OK but there was no output from the Powerbox. I thought it was a faulty Powerbox, but no! Turned out I had trapped an alternator wire, grounding it to the chassis. Worth checking in your case?
David
Use a multimeter (very che…
Use a multimeter (very cheap if you don't have one) to check the voltage output from the power box. Should be approx 14.5 volts. I have just had a similar problem - turned out to be a corroded alrernator connection plus the main feed wire adrift at the light switch - always more fun when 2 things fail at once.
Substitute the battery if…
Substitute the battery if you can get or have a spare. Having just installed a new rectifier / regulator, I had to make new a new loom from the alternator to the rectifier as there was so many connections on my MKIII that all seemed to be connected to the alternator output - it was easier to run new than check them all for continuity and corrosion. After much testing and though a lot pointed to the battery, replaced it and now it is astonishing how much effect the old battery was having on the charging circuit.
I believe that the anti-sulpahting style batteries fail by increasing their internal resistance, so despite failing to accept and hold charge they also incease the loading of the whole electric circuit - after all, it is just another component in the circuit and they are most likely to fail in this modern age.
Hi again - just measured t…
Hi again - just measured the output from the Alterntor, its at 10v AC - sounds too low right?
Regards - Paul.
Hi Paul, The problem with…
Hi Paul,
The problem with measuring the AC from the alternator is that your voltmeter will be measuring the RMS voltage which is only valid if you have a sine wave. You will not be getting a good sine wave out of your alternator.
Having said that I would expect to see a bit more than 10V AC.
Try disconnecting the alternator and connect a headlight bulb across the output, not a brake light bulb or similar, you need something that will load the system.
Start the bike and the light should be fairly bright at tickover, take the revs up a little and it will get brighter, take it up more and you will have a blown bulb !
If it is dim then your alternator needs investigating. If it is bright then you need to start working your way through the wiring. You say you have swapped the Boyer power box and the battery. it does not leave a lot left.
I'm positive (electrical…
I'm positive (electrical joke) that's too low. As stated previously DC charging voltage is approaching 14 volts. Looks like you need a new stator.
You should be looking for…
You should be looking for a very low resistance between the two stator wires, ie less than 1 ohm. ( disconnected from the bikes wiring ) There should be no continuity at all between either wire & the metal body.
Having satisfied yourself that all is ok, test with the headlight bulb as Tony has described earlier, then also connect the bulb between one wire & earth, then the other wire & earth, you should get no light at all. If ok, reconnect the stator wiring.
Next step is to disconnect the output from the powerbox & connect in an ammeter, start the engine & you should see the ammeter register a charge, turn on the headlight, rev to about 3000rpm & you should see about 9amp charge for an RM21.
If you see significantly less than 9amps, it would suggest failed stator windings or, more likely, weak rotor magnets. A crude check for this is to see if each magnetic segment will hold the weight of the rotor, use a screwdriver or similar to pick the rotor up, if any segment will not hold itâs weight, itâs almost certainly the root of your problem. Even if it passes this test, if itâs more than a few years old, a new one will invariably improve charging outputs.
Regards, Tim
The only problem I've had…
The only problem I've had with the rotor was the centre becoming loose from the magnets. This was after 38 years and 145,000 miles. Could be wrong, but I reckon it's worth changing the stator first, after checks, before splashing out on a rotor.
Previously simon_ratcliff…
Worth checking the air gap between the rotor and the stator too. If the stator has been rubbing on the rotor through misalignment it will have worn a part of the stator away and increased the air gap, hence reduced output. Check for bits of black debris in the chain case.
A mate has lent me a secon…
A mate has lent me a second hand rota and stator.
First I replaced the rota and installed the original stator â I got 13.5 v at the battery and 12v with the lights on.
Then I replaced the stator (which did not look very good and had many cracks) â I then see 12.3v at the battery and 11.5v with the lights on.
So I switched back to my original stator and the loan rota â disconnecting the alternator leads and firing the bike up I see 16 amps across the leads â much better than the original 10 amps.
The original rota is a Lucas item and has stamped on it 5 and 72 â which I assume is May 1972 about 10 years younger than me!
I just tried the weight test using a spanner and the original rota will hold its own weight on all segments.
So I will replace the rota with a new item, so I can return the loaner.
The only bit that bothers me is the low charging light remained on during all the above tests, even with the best combination of the loaner rota and the original stator.
Regards â Paul.
One more questions please…
One more questions please - I'll replace both the alterntor and rota - is it worth getting the high output alternator 200w?
Thanks again - Paul.
I'll be happy to admit I…
I'll be happy to admit I was wrong and Tim was correct with his diagnosis. Every day's a school day.
Higher output is obviously better but you'll need a compatible regulator/rectifier to suit the stator which could be single or three phase.
Paul, Sounds like youâre…
Paul, Sounds like youâre on the right track, always good when you can test by substitution. Re high output alternators, as Simon says, if you go three phase you will need to change the powerbox as well & often the higher output single phase units only provide more watts at high RPMâs, at lower RPMâs they may actually provide less than an RM21. Good if you ride at speed/higher RPMâs most of the time but if your riding is mostly pottering around back lanes or in traffic, the RM21 may be a better bet.
I actually run an RM21 on my electric start in conjunction with a high cranking amps battery as I have the bike geared for very relaxed cruising & found that with lights on I had to ride like a lunatic or hold third gear for the RM23 to keep the battery topped up. The RM21 is coping much better as it delivers more watts at lower RPMâs & I use the electric start pretty much all the time. An RM21 in good fettle should be easily capable of looking after the needs of a battery that only has ignition & lights to put a demand on it.
With regard your charge light, what do you have? If you still have the old assimilator, Iâm amazed itâs still doing anything & I wouldnât take too much notice of it, amongst the many thing they donât like are heat & vibration so Norton in their wisdom hung it in a spring right above the cylinder head. Interestingly, Thwaites use exactly the same unit on their dumpers of the period, they bolt them to a substantial steel bulkhead away from any heat & with minimal vibration & Iâve only know one to fail in that application, & that was so old the case had virtually corroded away & the damp had got to it.
Regards, Tim
Paul, Please measure the d…
Paul,
Please measure the diameter of both Rotas. The air gap has only to be slightly enlarged for the charge rate to drop off.
