i recently replaced the clutch cable on my '56 ES2 but has stretched so far I've run out of adjustment. Can anyone recommend a supplier of traditional heavy duty replacements?
thanks
stuart
Previously stuart_munroe w…
Hi Stuart... Have you re-a…
Hi Stuart...Have you re-adjusted the centre screw on the clutch pressure plate?
Cables don't stretch even thin ones.
I would remove the primary chain cover and do the correct clutch adjustment and it's very likely that all the adjustment range will re-appear. Don't forget to adjust the cable adjuster to give MAXIMUM slack BEFORE doing the centre screw adjustment...Hopefully you know how to do this, but dead simple and if you have never done it before just ask.....Les
Previously stuart_munroe wrote:
J.J. Cables of HIllsfield Farm, Warwick, CV35 0QB, Tel. 01926651470, make really good cables, give them a ring.
