Early Dominator. Rocker Return Pressure Valve.
Hi Chaps. Well the name of the part in question above is one I have had to make up as I can't find reference to it anywhere.
So just to be certain you know what I'm talking about, I am referring to the small in line pressure valve that screws into the oil return union that screws into the oil tank. Its purpose, it seems, is to encourage oil to travel up to the rockers via the feed pipe. Perhaps many have not seen one but it is is a type of pressure relief valve that has a small coil spring that restricts the easy flow back to the tank and forces oil to the head, only opening I would imagine when the pressure rises above a low PSI figure to allow oil to return normally to the tank.
Anyway, does anyone know where these are still sold or does anyone know of a photo of one on-line that they could direct me to please?...many Thanks....Les
Hi Les, Interesting!, this was not carried on to the later Dommies which suffered poor lube flow to the rockers. If you are missing the parts you could do what i have done , I removed the return fittng in the tank(no need to drain the oil ) drilled it and tapped it to fit a brass gas jet (from a n/sea gas conversion !) I then drilled the jet the same size as a jubilee return and tried it out. If the oiling to the rockers is too good just drill out to the next drill size till your happy. (are we ever happy?!)
Alternatively, if gas jets are not to hand, tap a 6mm thread, drill a hole through a short 6mm bolt, loctite in and cut the bolt head off. As Robert says, experiment with the size of the orifice....
Hi Robert. Thanks for showing interest. Yes, I was unaware of this part and only noticed it shortly before fitting it back after the total refurb. Obviously I can't show a photo of it now it's back in. So I do have one but was thinking about the way I fitted it and wanted to make certain I can remember it correctly.
You (and maybe others) might want to fit one, if like you, they have oil shortages to the rocker box. It would be quite simple to make by using a suitable size bolt (head removed) of about an inch long drilled right through and a slightly bigger thread formed only half way through this hole. The whole thing screws into the oil return union at the tank. A small ball bearing is then dropped into the hole (which is tapped in to seat the ball on the smaller diameter untapped section of the bolt) A light spring then added which is held in place with a drilled grub screw (to let oil flow through it and back to the tank)
The action is as follows: Oil returning to the tank is stopped by the ball....the oil is forced to go to the rockers.....as pressure builds in the rocker shafts, the spring is lifted to allow the ball bearing to lift off the seal and pass excess oil back to the tank.
In practice, viewing the return flow via the filler aperture, it is no different to bikes without the valve as the full flow return after starting looks continuous and plentiful, but hopefully, more oil than would be the case without it, is indeed getting up to the rocker gear.
Strangely though, by stopping the flow by blocking with a finger immediately builds up pressure and forces the finger off, so I was puzzled by this and wanted to be sure of what was going on.....I would have imagined that the oil would have been deflected to the rockers as it does on bikes without the valve?
Hope the valve description is of some use and could draw it but only from memory at the moment.
Les
PS...Happy? I guess it's all relative, and you can always tell yourself you are whatever the situation.
PSS Thanks also to Ian .
hi les,this question arose on the model 7 site last year,someone asking a similar question to yours.there was one response which included a pic of the item .he has a model 7(dont know what year)but says it was fitted to his bike which is completely original. apparently its mentioned in roy bacons book,norton twin restoration,page 95,but suggests it was for a lightweight,jubilee?.i dont know any more about it other than the writer of the post says it was a standard fitting on model 7 machines.
oil-tank-return-pipe-adaptor-jpg
Ahhh...Thanks very much Les. Yes that's it and my description of it being a separate parts that screws into the oil tank union was wrong....sorry if I misled anyone earlier. The whole union forms part of the valve so it might make a DIY modification more easy perhaps, hard to say without hands on...depends on the bore hole of the union....
Anyway, my '53 twin did have one as standard ...well I thought it was a standard fitment but yes, Roy Bacon does mention that type of valve was only fitted on the Jubilee so it seems the original owner might well have fitted it to give extra oiling up top. I will see if the Jubilee parts description shows this but the Norton Model 7 and 88 parts book does not show the oil tank and fittings so hard to know if it was a standard feature ...Roy could have been wrong of course!
The photo does prove to me that I could not have fitted it wrongly...there can only be one way.
Will attempt to find the parts number and come back on it, perhaps if this was available others might want to use it?
...Many Thanks again.
Les.
Below is from my John Hudson Notes.
He mentions a restrictor rather than a valve. I guess that technically a restrictor is a form of valve.
If I remember correctly the top of the oil return pipe in the tank is trappedflat with two small holes drilled for the oil to exit and these offer some restriction. For the Jubilee model we made a special oil tank return union adaptor and the tank end of this had approximately the same size of hole as the transverse hole through which the oil passed up the rocker feed pipe. I think both these holes should be 7/64" or 2.78mm in diameter. You can restrict an existing oil tank adaptor by tapping the tank end for a small grub screw drilled 2.78mm to suit.
hi les,looking again at past posts there is a part number of 22148 mentioned.i input this number in the search box and a load of information about the jubilee and navigator is mentioned,explaining the mod.it would be interesting to know if and where this part is available,my 55 m7 is currently without one, les
Hi Phil and Les...thanks for your info....The valve IS available from ANDOVER NORTON for £13.50 + vat...they refer to it as an OIL RETURN ADAPTOR (WITH FLOW RESTRICTOR) part number 22148. I guess it would be quite easy to call them to actually ask if it was as the photo above shows (my one is identical)..IE: a spring controlled ball valve restriction rather than a smaller orifice.
Strangely, after checking every parts manual relevant for both M7 and Jubilee I still can't find it mentioned or any drawings but at least you can buy one.
If I get time I will phone Andover Norton tomorrow and get back here.
Thanks again on this detail.
Les
My Model 88 suffered from insufficient rocker oil. Many years ago, I read in one of the Norton books (I thought it was PL Garrat, but failed to find it on a read through) of a Factory recommended modification
The Factory mod was to use an oil tank union from a Jubilee. It has a smaller hole for the oil to pass through into the oil tank, and so more oil goes up-top. Because Jubilees were not sold in New Zealand, I made a disc with the same size hole as the Jubilee union, and silver soldered it on.
In one of my 1954 Model 7 & 88 parts books there is a reference to H12/1055 as an Oil Tank Return Pipe Adaptor.
Whether this is the part everyone is talking about I know not. An Internet seach has not helped much. But did turn up the Norvil site section showing conversions of old part numbers to later equivalents.
Thanks to Paul and Phil again for some more information and suggestions.
It is very odd that there are no factory listings or drawings of the "adapter" but the photo supplied by Les Croston (see repeated photo via link below) is definitely the same device I have. This small pressure operated valve is without question better than any restriction in the return as the valve opens at a predetermined (light) pressure.. As you all know, the rockers are higher than the oil tank return spout so there is no reason that oil should rise up the rocker pipe. With cold thicker oil, enough pressure is created by the outlet pipe restricted nozzle but after the sump is scavenged 50% of the return flow is air that escapes so easily that it doesn't push any oil up the rocker pipe.
However with a pressure sensing ball valve, irrespective of oil viscocity or whether the flow is aerated, the same restriction to the return flow is created to ensure there is sufficient "push" on the oil to get it above the outlet and up to the rockers. Furthermore, should the return oil be cold and thick and pumping fast from a wet sump condition and high revs, it prevents excessive pressure build up on the scavenge side of the pump that a tightly restricted orifice will create. The pressure valve device will keep the delivery pressure to the head constant regardless of conditions and allow oil to flow freely to the tank when large amounts of oil are on the move.
What seems very strange is that this simple, cheap device was never continued to be fitted. It is foolproof. I really cannot think of any downsides to it.
Les
http://www.nortonownersclub.org/noc-chat/technical2-heavy-twins-forum/966632969/166594136/oil-tank-return-pipe-adaptor-jpg
Many years ago I used to take my 650 to regular Track Days and give it a good hammering. This bike's engine was vinatge 1963 so had the 3 start oil pump gears and return pipe feed to the rockers. Little oil was getting to the rockers. I could see the level rise up the the clear plastic feed pipe but then stop when level with the top of the oil tank.
I needed increase the flow and toyed with the idea of fitting a Jubilee type restrictor.......but then discovered that I could make a mod that was simpler and had a similar effect.
I took a 4" length of 5/16" or 3/8" rubber hose and slit it lengthways. I then wrapped this over the return pipe inside the tank so that it covered the hole in this pipe. I did plan to cable tie it in place but found that unnecessary. It worked fine with enough give in the rubber hose to allow oil back to the tank but also enough pressure created to push some regular bursts up to the rockers.
Just spoke to Ashley at "Andover Norton"....what a great bloke, ....very helpful and enthusiastic. Anyway, the item 22148 is now out of stock and was probably a batch of original items and unfortunately no details remain. However, if one could be located for inspection he is very willing to get some made up and has undertaken to locate one himself which I consider to be incredibly generous of him...might be some time but an update will follow.
Les
Les
Curious, I found it on their site (Andover Norton's) and was able to "add to cart" with no mention of it being out of stock. Perhaps they need to update their system so it indicates that before you try to make the purchase.
Previously Bruce Mitchell wrote:
"Curious, I found it on their site (Andover Norton's) and was able to "add to cart" with no mention of it being out of stock. Perhaps they need to update their system so it indicates that before you try to make the purchase".
Hi Bruce...When I spoke to Ashley of Andover Norton he tried to find one and said they were out of stock he commented that they need to modify their web site and computer so it is up to date with their stock level so in fact they don't have one currently.
_____________________
Phil.
Indeed the NOC shop does have one!!. Now the important thing is to see if this version has the spring loaded ball valve....is there a chance of getting in touch with the shop people to check if they are like this please? I don't know what their number is otherwise I would phone them.....Les
