Greetings all,
I did search this site for previous posts, but while there were some communications circa 2012, only general discussions / statements / information, no measurements for offset or other detailed âHints & Kinks.' I am just starting to rebuild the wheels for my 1964 650 SS restoration with alloy valance rims, SS spokes etc. Front wheel is fine, like for like, but wheel builder has asked for any âspecial offsets for the rear. I have measured the wheel that was supplied with the frame against a stock commando wheel and they are identical. While wheel builder has rebuilt Commando's before, has not tackled this particular set up / non-standard configuration. I am concerned that this may not be the full quid.......
Belt drive will have no cush-drive, hence the choice of Commando rear wheel. Otherwise all stock WM-2 x 19".
Details and measurements would be appreciated, otherwise I will have to fully assemble all the old stuff and check sprocket alignment and placement within swinging arm. I take it the wheel centre line is equally spaced or âcentralâ within the swinging arm?
Excuse my ignorance but this mega project was purchased in boxes!
Regards Steve
The spoke flanges are offs…
Thanks Phil, I also have a…
Thanks Phil,
I also have a model 50 (1961 Slim-line) with stock hubs, so will check that too, as the rear rim has been replaced, but not by me, so that also may / may not be a good reference. Of course I could have trusted this as a bench-mark, but as I had to fix quite a lot of 'non-standard deviationsâ on the M-50 bike to get her right, but I did not check the rims etc. for alignment, so this could be wrong.
However, now I have confirmed dimensions this is another job for me! While the M050 handles OK, she is does not deliver sufficient power for a traffic light grand prix or a Fleet bends experienceâ?â?. While we are on the Slimline wheel rim alignment subject, I take it the front rim should be central within the RoadHolderâs too (rim centreline / rim edge measured to inside fork leg) or is it more prudent to use a plumb bob or similar reference from the headstock centre vs. rim centre line or is there some offset there? Again apologies if this has been answered elsewhere, but got to get these bikes ready, or at least one of them, for the Distinguished Gentleman's Ride Sunday 25th September 2016, Commando is last resort but would be nice to take something older and as the final fall back is the BMW R60-CafÃ? but I would prefer to not mention the war!
Not into propaganda and a bit off topic, but ALL you chaps, this is worth a look: https://au.movember.com/mens-health/we-need-to-talk
Stay upright!
Regards Steve
A bit confused , quite new…
A bit confused , quite new to the Norton, although it has been resting at the back of the shed for 18+ yrs,, I have just had to replace the clutch centre and realise now that it has no shock absorber in it unlike the earlier AMC clutches so I'm assuming there is some absorbing rubbers? at the rear hub,
however my confusion is that with the earlier clutch mentioned here, would this not have an absorber in the spider and is it not possible to obtain one for a belt driven clutch after all it only replaces the chain and outer basket. or am I missing something here? kind regards
Previously richard_woolnou…
Yes, belt drive kits all seem to use the Commando clutch centre. I believe they modify it to fit Dominators. In any case, no cush drive. The belt itself does not transmit shock like a chain though.
Note to troll: I did not say the belt is a shock absorber although you may try to convince everyone I said that. No one ever checks back to what was originally said.
The early Commando used th…
The early Commando used the diaphram clutch and Dommie type of rear bolt up wheel. This had no shock absorbers in its transmission system at all. The factory must have owned 'Sprockets R'Us'!!!
Do owners of early Command…
Do owners of early Commandos report problems that might be attributed to the lack of cush drive shock absorber? (Those rubbers in the cush drive are jammed in incredibly tightly. I wonder how effective they really are. They are after all just the same in a prewar 12HP single cylinder side valve and a late 1960's twin cylinder 45HP(?) Atlas.)
And although belts may (or may not) be as stiff as chains, they do have the advantage of providing a constant velocity drive unlike a chain. That alone might justify the desirability of a cush drive with a chain but less need with a belt drive since the belt provides an inherently smoother drive.
Surely the great majority of those who convert Dommies to belt drive do not add the cost of a Commando rear wheel, do they? And do they report harsh drive as a result of fitting a belt? As far as I can tell they are all pleased with the change.
well, well, well, never cr…
well, well, well, never crossed my mind before, shock absorbion, cush drive, whatever a pedant wishes to call it, I'm assuming now that my April 1969 will probably have no cushioning effect either at the clutch or rear wheel!/
wassabit about a troll mean pse?
kind regards
My Dominator cafÃ? racer…
My Dominator cafÃ? racer in a Wideline featherbed frame has a belt drive clutch and the Commando cush drive rear wheel fitted to it as the Commando clutch does not have a cush drive in it. This was done for me a few years ago, and the conversion will work for a Slimline frame also. The Commando's rear wheel off set is 39mm.
Hi Anthony, I take it the…
Hi Anthony, I take it the Commandorear wheel hub centre line is equally spaced or âcentralâ within the SlimLine swinging arm? So where is the 39mm 'offset' reference, the sprocket side?
Thanks.
Rgds Steve
My 1970 Commando has no cu…
My 1970 Commando has no cush drive and hasn't caused me one iota of problems in the last 40 years
kind regards
A troll is someone who responds to a post but builds in some distortion so that you appear to say something stupid or incorrect. I have been attracting them lately. Not so much on this forum. For instance, if I say "If you remove 2 clutch plates you may need to shorten your push rod." The troll will post back "If you shorten your push rod too much the clutch won't work at all. It's a stupid idea."
Now other forum users will all agree that the short push rod is a stupid idea, not bothering to read the original post. The British Iron forum is probably the worst for this. Why do they do it? It gives their life meaning.
By the way, I've never heard it called a "cushioning effector" before.
hello Jonathan, he, he, he…
hello Jonathan, he, he, he, I've never heard of a 'cushioning effector ' either but then I used the words 'cushioning effect' most kind regards
Now you see what I mean.
If you want to use a genuine Commando wheel in a Dominator rear end then you must re-align the spoking so that the rim is central to the hub centre. A quick check with a Dunlop WM2 wheel is to run a long straight edge across the sprocket side hub face from rim to rim. If there is more than a 1mm gap anywhere there is a problem.
John Hudson said that, on Dominator rear wheels, the face of the left side bearing boss (the bit that sticks inside the brake drum) should be 31.75mm above the WM2 rim edge.
