Brake cam
Does anyone know where I could lay my hands on two brake oppertating cams for a 1950 ES2? Mine are badly worn and the usual sources don't seem to stock them. If they aren't available I guess they could be made, but do they need to be hardened to avoid wear?
I changed the ones on my 16H for Commando cams. They fitted perfectly, the only difference was the thread on the nut. I'm sure they'll fit a plunger ES2 as well.
I got a commando one from RGM and its considerably longer than the origonal. Are there different ones? Where did you get it from?
