Atlas valve guides
Hi all.
Having stripped down the head on my 1968 Atlas, I found one of the valve guides (right hand exhaust) a cold push fit into the casting. I duly pushed it out and measured the hole it left, thinking that if it had been previously run for longer than a small time the hole maybe oval. It wasn't, but measured at .501. The normal cast iron valve is .499 to .4995 and I was lucky enough to find a pair of G454 guides at +2thou. They were however phosphor-bronze material. Could I replace just the one valve guide with the oversized one, given the different materials, or should I have one turned down to .499 and replace the pair? Comments/views very welcomed. I am not averse to heating the head to 250 and freezing the guides to knock other one out and a pair of new ones in. Thanks in advance.
Neil
Hiyah Neil - When I found that a similar new guide was only a push fit into a cold casting I used a suitable locktite adhesive after I had cleaned the hole down into the combustion chamber adequately. It's been fine for many years. There should be no problem with just fitting one phosphor-bronze oversize guide however. It'll save on the valve lapping procedure if nothing else assuming the others aren't leaking. A quick test with white spirit will prove that. Why would you strip a head anyway ? Was it burning oil of just noisy ?. They did have that stupid pressure fed rocker system on the late Atlas's. Put a jet in it - that system is more trouble than it's worth. Get riding asap, Autumn's on the way. Cheers, Howard
yes carlboroe bronze valve guides are the best see RGM MOTORS forget the old cast iron ones that break inside the guild holes and when they do they make a real mess of things that costs a small fortune to put right , believe me its not cheap even though your a skilled engineer yours anna j
Thanks for the early guidance. Would thread lock or bearing lock be suitable. Also, if I did see off the pressure fed oiling system (disconnecting it) what would be substituting it? Seems to me the oiling of the upper rocker box area is a vital part of smooth trouble free running, if the system is working correctly.
If it was a later mod by those at Norton, what was the earlier version, ? and was it a poor performer?. Was it something that the Commando would inherit with all the other later mods that were proposed for that engine.
My Norton started to be refurbished by the previous owner, but only cosmetically and not mechanically. I bought it as a project, knowing I would tear it right down (Frame and other bits away being powder coated as we speak). Finding the loose valve guide has justified me taking it down. Rebuild starts over the winter. Thanks for comments so far, would appreciate more to get a general concensus on the way forward.
Neil - Bearing lock will be adequate. There are lots of threads about pressure fed rocker feed system problems on this Message board and there are solutions mentioned. If you are getting over-oiling symptoms you could revert to the early Atlas method but it will be quite expensive to change the whole system ( scrolled rocker spindles, three start oil pump gears, oil tank unions etc ). Several people have restricted the flow to the rockers rather than do all that. If you enter "Jet fitted in rocker feed" into the Search site window you will find threads and suggestions. I should go for the fitting of a jet into the timing cover or banjo bolt ( a pilot jet from a Monobloc carb). Experiment at will with different sizes. Obviously the jet will have to have a smaller hole than timing cover banjo bolt. The rockers and valve gear can run dry satisfactorily for several miles if you want to prove that the over-oiling is caused by the high pressure feed. People have brazed up the hole in the bolt and then re-drilled from very small to find a suitable solution. Paul Dunstall used to sell a special banjo bolt with 25 stamped on the head to stop over-oiling. Could have been 25 thou hole ?? Good luck , Howard
Hello Over oiling is caused by poor drainage there is drain holes in the cylinder head and these get blocked so if you have stripped your cylinder head is a good idea to clean all the drain holes you find then at the sides of the valve spring seats collars, And your Atlas was not built at Norton workshops by then atlas was built by AMC Plumstead in London the engines were built at wolverhampton shops and old valve guide holes need reaming and smoothing out before fitting new valve guides and you must heat the cylinder head to over 200 degrees fahrenheit the kitchen oven is the best way of heating the cylinder head for 30 mins get it good and hot, and then fit the valve guide cold is a good idea to place the valve guides in the freezer over night you need a good interference fit, and do not forget the clean the oilways at the back of the cylinder barrel as well as the right hand crank case elbow oilway, On the exhaust side the oil runs down the push rod tunnels and lubs the cam followers and cam shaft and some of this is blown out of the cam breather to open air yours anna j
Used Loctite 638 and put a piece of studding, large washer on the vaklve seat and 2 nuts to keep it under pressure overnight.. Job well and truly done. Tighter than a duck's a***.
Thanks to all contributors.
hello if its not interference fitted it will come lose in times as over size guides are made to be interference fitted and you reame the guide hole under size then heat the cylinder so the guide fit snug and you will not need loctite 638 or any other stuff and I never now use cast iron guides any more both my bikes have bronze guides in now witch are ten time better, yours anna j
I feel like I've had a mild bollocking from Anna. New age materials can and do overcome age old problems. The Locktite 638 is more than sufficient to stop the valve guide loosening , considering there are no shearing stresses, it just needs to be kept in place. If I tried to break the bond between the two components i would break the head first.. Have a precision engineer friend who swears by the attributes of modern compounds like this. Cant all be purists that can make an easy job difficult because 'it wasn't done that way' in the past.
Not trying to offend anyone, but modern stuff keeps these old 'bikes alive, kicking and ticking.
Thanks all contributors.
Does the valve spring cup and heat insulating washer hold the valve guide down (if it is the shouldered type as per Dommie)?
Oddly - about bronze guides - Norton used bronze for tappet guides (set in the top of the crank case) before the War. But they were not subject to the same heat, and they stuck to cast iron valve guides in the head. No idea why they used both materials. The tappet guides are much more complicated, with hex nut on top and threaded shanks.
Previously Gordon Johnston wrote:
Are bronze valve guides ten times better? Proof required.
yes bronze are better as castiron guides break up in the head and sometimes will destroythe cylinder head, bronzeguide will not break up in the head and are far better just ask Roger at RGM motors he race tunes commandos with bronze guides fitted, and see Steve Maney he fits his own made bronze guides, and many other race parts he makes, including the 1006cc commando big engine kit, yours anna j
Hi David
No the spring base washer fits over the rebated shoulder that sticks up in the rocker box, but having tried to move the guide after 24 hours under nut and studding pressure, it seems it would need a small sledge hammer to break it out of the casting hole.The valve went straight back on its seat, and a light lapping in of all the valves saw no seepage of white spirit in the upturned filled head overnight. No springs fitted but a 40mm 1" drive socket (probably 200 grams) was laid onto the valve heads to exert a bit of weight/pressure to give it a fighting chance of keeping the fluid in the head. Proofing the adhesive compound works will now only be found by building it up and running it. I will post results, either way, as soon as I know something..
Thanks for the interest. Neil
