650 barrel/pushrod length differences
Hi all, I have a 1967 650SS that the previous owner fitted with an early [manxman] spiggitted barrel to, machining the late head to accept, I purchased the bike as a non runner and fully rebuilt it, sinse then completeing about 1500 miles on it during which i have had the head off twice to find the top of the valves "mushroomed" where the tappet adjuster contacts, is there any differences in puhrod /barrell lenth that would cause this? thanks Al
Previously Gordon Johnston wrote:
Shouldn't be happening. Might I suggest replacement valves from a reputable supplier?
Valves purchased from RGM Motors evan had the ends hardwelded with a material, boratec I beleive.
Al
There is definitely a big hint of soft valve ends here. Proper valve ends were Stellited or stainless.
But.....there are also a few other possible causes to check out.
Post 1965 engines had slightly shorter pushrods to compensate for the loss of the spigot. Later Valve lengths also changed slighly to get the rocker arm angle better. Have you got a mix of components? The adjuster scew on the rocker end usually gives a clue here with either no spare thread showing or too much.
Some people have fitted valve guides with almost zero valve stem clearance. There were quite a few of these on the cheapie bits market a few yeras ago. Some even had the Green Blob Logo hinting at official specification parts. These promptly seize up once the engine gets hot. Check that your valvs have not been tap dancing on the pistons.
Unleaded fuel has not helped with cylinder head refurbishment. Some NOC members have reported cases of the fitting unleaded valve seats and later finding that the heads of standard valves weld themselves to these seats.
