Hi all, I have a single R 926/26 Amal carb on the bike. Is this the correct carb for a 73 750 does anyone know? Thanks in advance.
930 on most 750s, 932 on…
The bike came with two carbs…
The bike came with two carbs, one fitted, I'm guessing I need to buy a 932 as I have the semi high compression RH6 head. D'OH!
Are the new Amals good? Ta.
Measure the inlet ports and…
Measure the inlet ports and the carb mounting stubs first. Fitting 32mm carbs is of limited value if you only have 30mm holes into the head.
I haven't used the new Amals so can't comment.
Amal Premiers
Measure the inside diameter of your inlet manifolds then match them to the carb 30mm for 930 or 32mm for 932.
I bought a new set of 932 Premiers from Burlens recently and can say the quality of these current carbs is better than they,ve ever been. An old set of original 932,s that came with the bike are crude by comparison.
I also bought a set of Mikuni RS38 flatsides from the USA for my Yamaha and not withstanding the obvious difference in design and function, the Premiers are every bit as well made.
930 on most 750s, 932 on Combat & 850. Twin carburettors were standard on all models. Single carb conversions would most likely use 932s. 930 = 30mm Amal Concentric Mk1. If you have only one 26mm carburettor you might find it a bit, err, sluggish.
926 were, I think, fitted to Tridents but then they did have three.
