          I have seen conflicting information on oil quantity for the long roadholders, both from factory sources.
The factory Maintenance and Instruction Manual quotes 1/4 pint [142cc].
Edgar Franks and PL Garrett in their Maintenance and repair books both quote 7oz [198cc].
What quantities are other owners putting in their forks?
I’ve always put about 200cc…
Oil quantity long roadholder forks
Thankyou for your input John. I think I will start at 150 and work my way up to 200
I’ve always put about 200cc of fairly thick oil in mine (40 or 50 grade) which works ok (unless you’ve got proper dampers, then ATF is thick enough)
John
