Santa brought me to be the guardian of this bitza with, based on Norton files, a special scrambler Manx engine .
I'm looking for any information that might help me piece together its history.
After years of loyal service, it is currently resting in its owner's garage, who is not looking to sell it.
I doubt that is a genuine…
In the washing machine ;-)
What do you think about the 6-fins cylinder?
A One-Off Perhaps?
The Bracebridge Factory built some Manx engined Scrambles bikes in the early 50s.
A lot of good bits there…
Neatly built up machine with a magnesium conical hub at the rear. Is that a nickled frame or moly tubing ? Bit special with a non cradle set up. Swing arm with rear adjusters also ….
It’s clearly been hung together in race trim for a few seasons so must have been reliable. I’m sure Richard will give us the heads up on that particular motor.
To fit an ID plate professionally shows more credit to its builder than a non, or corrupted Identity. Casings in this game were susceptible to internal and external damage, retaining the number on replacement casings shows integrity.
What area does it live in?  Should try raise some history on local scrambles entries. Or maybe the owner can fill in some history.  Les Archer made a huge impact on the European Motorcross scene on such a machine. With one of our members owning one of Archers machine in the South of France.  I’m sure there will be further to come on this one.
Very nice, desirable machine.
Thank you for your feedback,…
Thank you for your feedback, Jon.
The frame is chrome and the bike was bought in Switzerland about 35 years ago by the late owner.
Let's wait for Richard's and the person who owns one in the south of France.
Another Les Archer creation....
ended up in the US:
https://photos.thecreeper.net/Motorcycle-Stuff/Clubman-Awards-2014/i-f7Rfk7H/A
Help from the Records Dept.
Hi Christian, if you would like any help with the identification, please don't hesitate to email me at recordspostwar@nortonownersclub.org .
The plate that replaces the engine number appears to be missing the last digit 4507*. If you would like me to look into this further, let me know. Your crankcases look to be from the Featherbed era in style but Richard is probably the best bet for engine specification.
Kind regards,
Paul.
Manx scrambler.
Hi Christian/all.
Just getting sorted after one of the power cuts yesterday ! If the engine number is correct, this is a 1952 350 DOHC 40M which looks possible as the rear frame section looks like the early type featherbed with the upright shock absorbers. The bottom half of the engine also looks the same period which will be an 88mm long-stroke 350. The barrel looks a proprietary part with only 6 fins and it is possible this might be a conversion to make a short-stroke 500 which would explain the yellow race number plates that are used for the 500cc capacity class. The cylinder head fins have been drastically shaved back, so probably run on dope fuel, and the cambox although being a SOHC, will still fit the cylinder head. The forks and front wheel are obviously much later and also the AMC gearbox which looks a very tight fit against the engine.
Although the bike looks to have been built with purpose, I think it lacks the quality of build of the Archer machines. I would think this bike was built, copying as much as possible, the succesful early Archer specification at a later date. Having said all that, unless there are any records from Archers, nothing is definite and we can only use our best judgement.
Thank you for these details,…
Thank you for these details, and as you said we can only speculate.
Piston is 79.50mm
Piston is 79.50mm, and taken roughly, the stroke looks more like 100 than 88.
Thank you Richard for those details. Of course the frame could be a copy, and the engine a bitza itself.
Was the swingarm on Archer's bike oval or just round?
This came up on the singles…
This came up on the singles fb group - similar looking frame?
Submitted by Christian Wyss…
Submitted by Christian Wyss on Wed, 03/01/2024
In reply to Another Les Archer creation....by Michael Rettie
The best known
The best known with the curved frame from a Commando.
To my knowledge a commando frame wasn’t involved! -
Les Archers frame was based on a featherbed if thats what you mean?! The frame in your pic could be one of Eric Cheney’s he was good friends with Les. I suspect this is a replica bike build to race in the pre 60/65 class in the 90s/00s - I’d certainly be happy to take it around the track!
Dan
You're right Dan, my…
You're right Dan, my ignorance sometimes leads me into abysmal depths of error. It's surely based on a featherbed.
Good to know it could be a Cheney's one.
Thank you for those details.
Plenty of similarities…
…to the picture Dan put up. Front engine plates, footrest arrangement, carb. Strangely it seems to be a late 50’s machine that has had an extended life into pre 65 guise with what look to be Cerriani forks and small hub front wheel.
more pictures especially with tank off would be good
cheers
Here's a bike that could…
Here's a bike that could have the same cylinder, perhaps the same cylinder head with the extra cooling fins above the exhaust valve, the same air filter, the same rear frame.
Did all Manx' heads had extra fins on exhaust side?
Christian, I think that’s…
Christian, I think that’s one of Les Archers bikes, You probably know he successfully campaigned on it back in the day, As you describe his frame was sort of based on the Featherbed and had distinctive curved front downtubes as shown in the picture from the museum, there are some similarities with your bike but my guess is someone had Les’s bike in mind when the built it.
I’m asking around to see if anyone remembers or has any old pre 65 programmes it but as a non UK bike that might be a forlorn hope!
I’ve copied your pic below for ease of viewing!
It's probably not a Les Archer bike
Yes Dan, we can be sure it's probably not a bike built and raced by Les Archer. On the other hand, some parts of the engine resemble those found on Les Archer one, like the cylinder.
Christian Is it still in…
Christian
Is it still in Switzerland or in the UK? I know a few riders who would like to take it for a spin! (Or you could bring it to one of the Pre 65 classic Scrambles!
(Heres hoping)
Dan
Dan, it looks like you'll…
Dan, it looks like you'll have a lot of fun spinning it here and there, unfortunately it is not in UK anymore.
Mick Walker book.
Hi Christian/all.
Our camshaft Norton specialist Barry Stickland pointed me to Mick Walker's book " Manx Norton " in which he included a short chapter on Les Archer and his Nortons. I have attached scans of the 4 pages and if you zoom in on the photo of the engine, is does look very much like the subject of this post, but not sure on the cycle parts.
Thank you Richard, it looks…
Thank you Richard, it looks we're getting closer to the thing. The engine really looks like the one on the third photo. It could be nice to have a closer look at the engine number. And the bore also seems to match as in page 107.
The frame could be like the one on page 106. Except that the front section of the frame does not appear to be straight.
I doubt that is a genuine engine number. A metal label held on with screws just looks wrong to me. Puts a question mark over the whole bike. Also where is the upper bevel box cover?
