Manx 350 Carburettor - discuss!
So, here is my tale of woe. 1947 350 40M engine. As fitted to my 1947 40 Manx.
Restoration is going well. However I have now found a major issue with the carb fitted to the bike. I am aware that what is fitted was not original. It is a 10TT 36R. On stripping to refurbish I found that the main carburettor body, where the knurled ring screws onto the body to hold the carburettor top is completely U/S. There are bits missing from the thread and the knurled ring has had a slot cut into it and was gripping the thread by dint of a type of Jubilee Clip around the periphery to hold the ring on to the body. In short, the main body is scrap.
I can find plenty of 10TT's on the web but it seems the issue is the bore size. Most of the ones out there are  1 5/32" bore as fitted to the 500's etc. I cannot find an 1 3/32" bore anywhere. I will be scouring the autojumbles until I can find one.
However, Bacon lists the correct carb as an 1 3/32" RN carb. But I have been warned off of going down this route, even if I could get one! Likewise a GP. But a web search for an 1 3/32" one of either of those has thrown up nothing.
A very knowledgeable Norton Dealer that I know has said that a concentric would be better than the RN or the GP! I don't particularly want to go down this route. Even though my bike is a bit of a "Bitsa" I would like to get it close to correct.
So, the question is, what are the alternatives whilst I try and track down the correct carb? Or, ideally, does anyone actually have a spare carb or surplus body that I could purchase?
Over to you.
Thanks in advance for your sage words of wisdom.
Bill
My -59 40M came with a 35mm GP with same thread damage. Originally it had a slightly smaller one. He who raced it in the sixties recommended the slot and jubilee solution. Unable to find a same size GP, I ended up fitting a Gardner 35mm. Don't look right but with help from other racers got it running well. It seems that the Manx gradually got larger and larger carburettors. So I think that your bike could run well with a 1 5/32 TT. A 40M is lacking power at low revs anyway.
Float chambers. The matchbox I got from Burlen didn't give enough at long straights. Fitted a Gardner one, no more problem. But hopefully you have a decent more originally looking one.
The Dellorto SSi  is pretty much a copy of the TT ,but they can be a bit pricey and spares a bit scarce. If you want to be really different I have a brand new Bowden 29  !  , The Works tried them out in practice one  year but chickened out when they realised  they would be in trouble with Amal if they won !.
I have a 1 3/32" TT.  I inherited from my father, who got it in a box of ohc Norton stuff in 1954. It was probably fitted to an ohc Norton originally. I had been thinking of putting it on a V-twin project, but its pair is 1 1/8", the size I actually want.  I must have a look at it, can do on Monday.
In reply to by paul_standeven
Paul, That would be marvellous! Please let me know and maybe we can come to some arrangement?
Kind regards
Bill
In reply to by william_monteith
Hi Paul,
Did you manage to have a look for the 1 3/32 TT carb? I still cannot find anything on line and am waiting to get to a suitable autojumble.
Kind regards
Bill
I expected to be able to have a look for it over a week ago, and have not managed it yet, spent all the available time on putting my Dominator back to together and a trip to a machine-shop.  I know exactly where that TT is, I have a box of racing carb parts in a box of Amal stuff.  I hope it will happen next week.
and had a look at the two TT bodies.  One is a brass+alloy casting, 1 1/8" bore and stamped as such. The other is an alloy casting, stamped 1 3/32", but measures at 1.15" ie more like a 1 5/32" bore.  It's definitely stamped 1 3/32", but has evidently been over bored.  If my father had realized that it was actually 1 5/32" it would have gone on his 500 alloy Inter.
I think this carburettor is too large for your long-stroke 350 Manx.
Thanks for looking Paul.
I guess that it is back to scouring the autojumbles and hoping for a miracle!
Many thanks Dan,
However, I am now sorted. I found one on ebay, in Denmark of all places. £250 later it was mine. I have rejetted it and cleaned it up and it looks the part. All I have to do now is see if it runs! And that will be many months away.
Thanks again.
