hello,
es2 engine 1955. should the main timing cover have a gasket .i have made engine gaskets before. if i were to fit one. then i was wondering if i need to shim the timing cogs. and use a rubber type oil seal on the pump, and not the fibre washer . just thinking of the gasket making clearances changes between the timing cogs and the oil pump to cover. i have used sealer on the cover before and the oil just slowly drips out over time.i have straightened the cover mateing surfaces ect.
thanks
barry.
From 'Franks'
thank you, for the…
thank you, for the information David. it all helps.
Barry
I would not think that…
I would not think that shimming the timing gears is necessary.
Considering engine very cold to very hot, the axial clearances of the cams will be all over the place.
I would try to find a nice thin gasket material, pull the timing case up evenly, and not worry about it.
From 'Franks'
