Hi everyone. Iam going to take the cylinder head off to decarbon and have a look at it has its leaking oil on head gasket. Where it the best place to purchase a top end gasket set for 1948 model 18?
Also what are torque settings for the rocker box bolts and cylinder head ,
Regards Paul Bennett
Paul,“RacingNorton.co.uk”…
Manual
https://user-92356451.cld.bz/Maintenance-Manual-and-Instruction-Book-16H-Big-4-18-and-ES2/6/#35
 Hope the link works?
Hi Nate,yes the link works,…
Hi Nate,yes the link works, but it's the same manual that I've got,
And it doesn't give any torque Settings.
Head gasket
Have you looked at NOC Spares, click on shop then spares. I had a quick scan and the Club may have one.
Hi Tim just ordered a decoke…
Hi Tim just ordered a decoke set
From the club site, I don't know how I missed it earlier.
There are no published…
There are no published Norton Singles torque settings. Tighten firmly with the correct length of spanner. The problem with socket sets (new things...just like torque wrenches..probably from America...never catch on...) is that all sockets are driven by the same length of handle.
If you search previous posts here, someone quotes 32 lb.ft. I've no idea if that's correct. Sounds about right...!
Cheers David, would that be…
Cheers David, would that be for the cylinder head or rocker box or both , what length of spanner is suitable!!!!
Regards Paul
Paul,
“RacingNorton.co.uk”. Will have everything you need for the top end of your Norton. The owner is very knowledgeable and honest with years of experience.
Good luck.
Nate.
