Hi, would anyone be willing to send me some pictures regarding an original handlebar layout as per my 1962 Norton model 50, also, did the factory use Amal or Doherty levers and what ammeter came with this model. There is also provision for a tyre pump, anyone know what make it was, many thanks David
There is plenty of photos on…
The 1962 Range
Perhaps the best book for close-up black and white images of original machines is Roy Bacon's "Norton Twins Restoration". Would it be an assumption too far that the singles and twins had similar controls ?
This scan shows a '61 99SS above and a '67 Atlas below. I suspect that the '61 model has Amal controls.
There is also a photo of a 1962 650SS fitted with what looks to be a late-pattern Apex inflator - one of these :- https://www.worthpoint.com/worthopedia/vintage-bicycle-pump-tyre-inflator-462806557
Richards pictures show bars…
Richards pictures show bars that are generally considered to be "straights" , not standard issue but on the optional lists .std bars have a rise of 2--3 inches .
There is plenty of photos on line and they should show a low rise bar drilled and tapped for a dip/ horn switch , plain blade levers 7/8” centers cable nipple to pivot , brake lever with choke mounted on top .
