Oil supply isolation valve
Can anyone tell me where I could get an oil supply isolation valve with the switch to earth the magneto so as the bike cannot be started when the oil isolated.
This this due to wet sumping problems. I have been draining the sump to date.
Kingpin Components sell these as do 'The Magneto Guys' but I believe they sell the Kingpin device. They cost about £40
Kingpin and The Magneto Guys are father and son ( or maybe the other way round) Its the same component and I recommend it.
I also recommend getting the adaptor to fit it to the oil tank rather than faff about with hoses. It makes the job a lot neater and more  solidly fixed.
This system will only work on 'killing' the mag if the mag has an electrical kill terminal. Also bear in mind I sell a Magneto ignition switch which works on this same principle and at the same time disconnects the battery. (Leaves the bike safer from little fingers fiddling with light switches and stuck stop light switches from flattening the battery! AOServices.)
In reply to by alan_osborn
Thanks for pointing that out.
