Hi
Is there a prop stand that will fit a 1938 Model 18 please ? If so then the suppliers details would be appreciated.
Dave
Have you considered the…
I can't see that stand…
I can't see that stand fitting the Model 18. Might be
ok for the ES2 frame however
I think...
... the front engine mounting would be very similar even for the open frame. The one I made (adapted from a set of alloy plates I had lying about) was easy enough to fabricate and only needed a couple of studs and spacers to be made up on the lathe.
Ah. ok, then who sells those…
Ah. ok, then who sells those Kawasaki mounts, and any part number, ? please ?
I have no experience of the…
I have no experience of the Vintelle stand only to observe it is a period accessory which might or might not be a reason to fit it. It is adjustable for uneven ground and appears to be easy to use..if you don't want (or aren't able) to pull a heavy bike onto its rear stand.
The Kawasaki stands...
.. are readily available from ebay for £10 - £15. You have to make a few easy mods such as removing the switch mounting.
Have you considered the Vintele stand? It's suitable for rigid frame.
