The various copies of my Norton manuals state that the main jet is #160 but there is no mention of what the needle jet should be ?
AMAL offers 7 different needle jet options for the 276 carb
Could anybody kindly advise what the "stock" factory needle-jet would have been please
Thanks,
Grant in Toronto
Grant...as you have found,…
According to my Amal book it…
According to my Amal book it concurs with David; .106 needle jet. As you say, 160 main jet, needle position 3, 6/0524 throttle valve.
The needle jet has a…
The needle jet has a reference 4/061-106 ,don't know if it makes a difference.
Thanks David, that was very…
Thanks David, that was very helpful
I wonder if you can also advise me on the correct throttle slide. There are 6 incremental variations in cutaway on the AMAL slides from the #2 to #6 versions. I may want to step up or step down a cutaway as this process proceeds. Never messed with the cutaway but by reducing the cutaway, I understand that I can make lower throttle zone more rich which I may need to do.
Do you have an idea what the stock "factory" cutaway number would have been ? My Haycraft "book of the Norton" says the "Throttle Valve" is 6/4 but that does not match up with current terminology on the AMAL web site.
thanks again,
Grant MacNeill,
Twelfth Fret Guitar Shop, Toronto
My book says 6/0524 with…
My book says 6/0524 with needle position 3 , Same as Ian's. !!th edition.
The 6/ is the designation of…
The 6/ is the designation of the card. A 6/4 is just slide number 4.
If you are setting up a non standard carb from scratch, you can start with a low number cutaway and progressively file it away. But with a standard setup there should be no need. And filed slides will annoy you in the future.
Thanks David. I have no…
Thanks David. I have no intention of messing with the slide but wanted to verify that it is the correct one. So...#4 slide it is. Thanks. I'll give the slide another careful look and probably find a number stamped into it. If it is #4 or has the current AMAL part number stamping 6/0524 then I won't worry and for the moment, focus on all the other variables to ensure that I have the correct jets
very helpful
Regards,
Grant
Different...
.. of course but my 1952 ES2 has a monobloc fitted and spat back a lot on opening the throttle. A change to the next richer slide (can't quite remember ATM but think it was 4 to 3.5) cured it.
David I checked today and…
David
I checked today and my slide has the number 4 stamped into it so all is well in ES2-land
Grant
Grant...as you have found, the size is not listed anywhere. My 276 has no marks on the needle jet. Almost always the size is .106.
