12v Battery for 16H
I’m after a new 12v dry cell battery for my 36’ 16H. Can anyone recommend where best to buy one from please, and is there a particular battery I need?
In reply to by ian_soady
Hi Ian, thanks for the reply. The bike originally had a 12v battery fitted when I had it. I used this for a while and found that since changing back to a dry cell 6v battery, the lighting isn’t as great now, (although I’m not out after dark, I have got back around dusk and that’s when you notice the difference).
So I was thinking of going back up to 12v as the 6v battery also doesn’t hold the charge as long as the 12v?
... need to check whether you have a 12 volt regulator fitted. Changing between 6 and 12 volts isn't just a matter of the battery - regulator and light bulbs also need to correspond. A 6 volt horn will survive on 12 but 12 volt horn on 6 volt supply will emit just a feeble peep.
This chap has prepared some useful stuff: https://www.matchlessclueless.com/electrical/
Hi Ian,
You can tell I know a lot about such thing, not!!
Thanks for the link; just having a cursory look at this site and it looks really useful! A bit of bedtime reading now for me before venturing forth. I assume the old original regulator on the bike will probably be 6v then I guess, therefore I’ll have a look this weekend to find out first.
