Hi
Can anyone suggest where I can locate the attached headlamp clamp for girder forks?
thanks and regards
Colin
They sit on a pair of steel…
Headlamp attaching clamp (Girder Forks)
Hi David
Thanks for the reply, yes I have the steel prongs its the connecting clamp (prong to headlamp i'm after) I'll try the items you suggested thanks
Regards Colin
Confused!!!
Colin:
I am confused....
Are you asking where you can locate and purchase the item(s) or are you asking where on the bike the clamps go?
Hi Michael
I wish to purchase the qty 2 clamps (which connect the headlamp stay's to the actual headlamp)
Regards Colin
Sorry Colin...I…
Sorry Colin...I misunderstood...(did you edit?)
Sorry cannot help although old fashioned cycle saddle clamps look similar, as do old rear view mirror clamps.
Have you tried Russell…
Have you tried Russell Motors? It's the kind of thing (small, old) that Les might have in a box. I don't know how many hours he works nowadays. Not Monday or Friday, but last year he was still in on Saturday mornings, and Tuesday to Thursday. Phone him...
Hi David
No I haven't but good suggestion I'll give him a call see if I can get through
Cheers Col
Prong diameter
I have various mirror clamps that may fit but need to know the diameter of the prong to see if they are suitable.
Philip.
Hi Philip
The diameter of the headlamp mounting point of the prong is 8mm wide and 25 mm in depth
Thanks Colin
They sit on a pair of steel prongs which screw into the girders below and behind the lamp.
