Centrifugal advance springs
Can someone tell me if the two little springs in the mechanical ignition advance unit in the '61 ES2 (it has coil ignition) should be identical?
The unit I received with the bike has two identical springs.
I have a description (off the internet) which states that there should be a stronger and a weaker spring with the stronger somewhat loose on its pins so that the weaker operates first - up to about 1400 (engine) rpm before the stronger spring engages.
I see no comment in the Lucas website about this, nor about any new springs on offer.
Any help anyone?
(Have a better New Year than 2020!!)
Mine are both the same. I can't believe the design is sophisticated enough to need a twin rated spring, and anything left loose ends up wearing things out. I await any other ideas!
is attached detailing all the technology of spark advance. (Year 2002)
A little long, but main points are in the first few pages. Explains a lot.
But David may be right, were 1960s engines this sophisticated?
Should the ES2 have different springs?
Going back some 50 years , I was running a supercharged  998cc Frogeye Healey, and was suffering crank and half shaft breakages,with pre-ignition knocking . I had to play with the advance unit  soften things down so it would get me to work across London. More recently I have modified a Ducati unit to give a wider range on a semi race motor to allow  starting without kickback. Lots of patience needed  .New springs a good idea or at least ensure the spring with least slack pulls the unit back to allow a slow tickover. The Distributor Doctor may have springs.
It would make sense to have two differing sets of springs. One set for a Magneto A/R unit and another for a Distributor 18/D2 sparky thing set-up.
.. for your comments.
Distributor Doctor inform me that the springs for the ES2 are in fact identical.
As a matter of fact, the distributor for the single is the 18D1, for the twin is 18D2.
