I have had my 961 for about 9 months and in that time i have loved and attimes questioned it.First about the bike, it is a 2010 961 sport that i bought used with 2000 miles on the clock,and the previous owner had it built as a 961se as he missed the first run of 200.Yes i had a gearbox problem, the stuck in gear one, but after talking to Sean at Norton and getting the bike to them, 2/3 weeks later i picked it up again with problem sorted, and i managed to put about 100 miles on it before the crap weather arrived. In those miles i noticed the gearbox was a better animal than the previous one. I have had a few electrical gremlins but they were easily sorted by me.To anyone with a 961 who has engine management light and neutral light flashing at you either get a small rubber boot to cover switch wires or pull them off and fill with electrical grease, as switch is right by rear chain and gets water and crud thrown at it, problem solved. I know a few problems and some people have taken a dislike to it ,and i for one do not mind constructive criticism,after all i could jump on the bandwagon and slag it off,as well as its owner, as i have good reason to but they have been very good to me so get my custom. A bike dealer i know has described the bike as pornography on wheels and has offered his wife in exchange for it!
Previously robert_mackenzi…
Hello Robert, It's good t…
Hello Robert,
It's good to have another happy 961 owner on the forum, and also good to hear Norton sorted the gearbox problem out quickly.
David
My 2013 has a rubber boot…
My 2013 has a rubber boot on that switch, I wonder when they updated it? Maybe other owners can help?
Previously bob_parsons wro…
Previously bob_parsons wrote:
Previously david_charlesworth wrote:Hello Robert,
David
Hello David, Itlooksas though Nortonknew there was a problem in that area and have now hopefully sorted that silly little problem out,is that not what you call getting it right.I have enclosed a photo of my bike but it has changed a little since it was taken,as i have now fitted oberon bar end mirrors andTriumphblack anodised billet aluminium brake and clutch fluid reservoirs, both of the same size as i like things symmetrical.They are really beautiful little bits of kit, much better than the mini gold fish bowls it came with.If you are looking for a rear standthe one i have is perfect for this bike it is an oxford OF821 and comes with both setsof lifting feet,rubber and hook,you only need to buy a set of 6mm bobbins. see you for now
Bob
Attachments norton-961-1024x768-jpg- Log in to post comments
David
Bob
Nice one Bob
Okay, I have made a real m…
Okay, I have made a real mess of this. I was posting from my phone and it said something about my browser being incompatible with the forum and the resultant post was a disaster !
To Robert: Yes I was referring to Norton noticing the problem and covering the switch with a rubber boot. I know the problem was fixed before 2013 but I was trying to narrow down the time frame !
And I want to add that the red with black bike is absolutely gorgeous!!
Had a look today, mine has no rubber boot, so sometime after theend of July 2012
David
Bob
Anyone requiring a tank bag for the 961 should consider one from SW-Motech which fits over a locking ring attached to the fuel filler flange.
Mine fits perfectly.
contct bonnie.wheeler@motohaus.com she will knpw the ring fitment and bag she supplied to me.
Russell
I've just come across thi…
I've just come across this thread and it relates directly to a problem I noticed for the first time this afternoon. I have a 2011 Commando 961 SE and today, for the first time, noticed my fuel indication symbol/light and my "N" neutral gear light come on intermittently.
What I did notice was that occasionally the gear NEUTRAL light (yâknow, the green âNâ) would flash on and then off again. The exact same thing was happening with theorange FUEL warning lightâ? again intermittently. The two warning lights (the green âNâ and theorangeâFUEL PUMPâ symbol) did not necessarily come on at the same time. It wasnât regularâ? just occasionally. At first I had the idea either or both would come on more when I - for example - used my indicator/s, but I donât *think* there was a correlation.Before I arrived home today, I stopped for some petrol (I like to have a full tank on getting home - saves any hassle when I go out for a run next time), and filled up with 8 litresâ? so there was still already 9 litres or so in the tankâ? no reason for the fuel warning light to flash on.When I got home, I started doing some amateurish fiddling around and right away I noticed that whenI barely touched one particular wire that goes into the transmission casing, it came away freely and with easeâ? as if it had been lying in position loosely and not fixed. I donât know what this wire is but it goes into the transmission casing on the right side (while seated) of the âbike. It has a sort-of elongated plastic cover to it.SEE ATTACHED PICSAnyway, this completely loose wire comes away freely and easily on just merely holding it.
Can anyone help? What is this wire? How do I tighten it to its location? Could this be the cause of the 'warning' symbols intermittently flashing on and off?
Any help/input/advice would be much appreciated.
Dan
Attachments img_3366-copy-jpg- Log in to post comments
Dan Get in touch with Nort…
Dan
Get in touch with Norton - they will have the answers.
Speak to Karen, who will put you in touch with Nick, the service technician. My experience is that if there is a problem with a component, they will replace or upgrade it at the next service. Or, if it is urgent, and a simple fix, they will send you a new part with fitting instructions.
Roger.
Hello from Finland. I am o…
Hello from Finland.
I am owner of 961 Cafe Racer. I have ownedthe bike for three years now. First summer went badly wrong when there was only 2000 miles driven with the bike, the valve spring broke and the valve dropped on the piston. New parts came from the factory and then thebike was fixed. Bike went broke on june and it took 9 months to repair.
Last summer was ok but this year I have had some air leaksbut I have fixed them. There was little rubber cap between thethrottle bodiesand there was air leaking from it. And some air hose leaks from air amount sensor. "Im not sure is that the right word in english sorry"
Last week the nut from cluth axel inside the cluth was loose. I repaired that also. Nothing major damage did not happened.
The low fuel light flashes even when the tank is full. That is a minor problemand I havent found the source for that.
Still the ups and downs that I have had. I really love the bike and I will get it fixed no matter what comes in the future.Thelocal dealer has beenvery helpful andnice,butwe have big country and long distanses so we have try to fix our bikes our selves. And when you fix the bike, you know yourbike alittle better all the time.
I also have 1950 Big4. I have had that bike for eight years. It has been much better bike than the new one. But the feelings when you drive them is so different and cool I would nevergive them away.
Jani Erola.
The low fuel warning light…
The low fuel warning light flashing is due to cable routing and Norton have a fix with a re-routed wire - I had this done earlier this year at the factory so your dealer should be able to request it.
Previously alan_sessions w…
Previously alan_sessions wrote:
The low fuel warning light flashing is due to cable routing and Norton have a fix with a re-roted wire - I had this done earlier this year at the factory so your dealer should be able to request it.
I can confirm this. It's a very easy fix and you can mount it yourself. But only flashing fuel light is solved with it and not flashing neutral light, if you observe this as well...
Good to hear that you have had good service from Norton, as I've had. Also that when you have had little electrical problems you have been able to sort them yourself . Most owners who have had old Norton's will have had experience doing their own maintenance and fault findingas it's essential ! )
John Mc
