MK3 drive side camshaft bush
Hi all,
Got a new bush to put in the drive side case (pt.no. 065425), the new one has a single hole in the bush what is the orientation of this ? The original never had this.
Kind regards,
Ian
The 200000 and 300000 series thin wall bush had an oiler hole within the bush and case.
325000+ oiler is beyond the inner end of the bush. So the bush shown serves both types. the plain bush does not serve the earlier engines . The original MKIII bush may well be obsoleted as it is not really relevant.
Thanks David,
Makes perfect sense, they dont tell you this when the bush is supplied.
Kind regards,
Ian
