Bike is 1959 Dommi '99'
I introduced this topic some time ago and received a lot of advice. Since then I've run the bike with the belt drive and commando clutch in place. Now, having looked inside the primary chain case I've found oil. It appears to be coming from the gearbox, but still need to investigate further. If it is from the gearbox in previous correspondence it was suggested that a 1/4" silver steel push rod would solve the porblem. Where should I look to buy such a thing and is it usable in this form or does it require heat treatment to harden it ?
The other possibility for oil in the chain case is that it is coming through the seal on the crankshaft. I did replace this seal when I rebuilt the engine but I imagine it is possible that it is leaking. However, this seems unlikely as I have no oil drips under the engine (the crankcase breather is piped away from this area so it can't be oil coming from that).
All advice/comments welcomed ?
Crankshaft Oil Seal
Oil is from gearbox, not crakshaft oil seal.
Phillip - now pulled it all to bits and found the oil on the clutch is all from the gearbox. The recently fitted crankshaft oil seal is still in tact with no leakage.
I've located an a gearbox push rod oil seal solution from Norvil. Currently waiting for delivery. In seeking to slove the problem there has been much said about the diameter of the push rod. Supposed to be 6mm. Some people suggested fitting a 1/4" dia rod. The one currently on my bike is 0.218" . According to Norvil it should be 0.233". Is anything standard on thes bikes ?
Given that Norvil are supplying me with the seal I have opted to buy their 0.233" dia. rod to go with it.I've also decided to switch to EP90 oil in the gearbox, although this seems to be a mighty contentious issue ! So many views on oils it's impossible to decide which way to go.
Rods
There must be a reason why Norton used something as odd as a 6 mm rod instead of a more common 1/4". A silver steel rod needs to be hardened, at least in the ends. I prefer to use two or three rods with a bearing ball or roller between them. I usually have a small amount of grease between the rod parts. Never experienced gearbox oil in the clutch, might be pure luck. An idea would be to check if the tiny ventilating hole in the box is clogged.
Gearbox Gremlins
I have just removed and dismantled my 650 gearbox in an attempt to cure the whine I was getting in third gear. This gearbox was built 10 years ago from a crate of bits I bought for £125. Everything in this crate looked usable so I just cleaned all the gears, bushes and bearings and them put the bits back together. I filled the box with Sythetic Gear Oil and it worked fine apart from the whine.
10 years and 8,000 miles a stuck drain plug and the whine encouraged me to take the box apart and do a major rebuild using an RGM refurb Kit costing £!53. Included in this Kit is a Layshaft roller bearing conversion.
Inside the gearbox there was no wear worth noting apart from the kickstart shaft bush which was near death. This was a pig to get out. In the end I drilled it as thin as possible and then chiselled the remainder out. The big surprises were the replacement 2nd & 3rd gear bushes which actually had more play in them than those they were replacing.
To get all the ball bearings out of the cases I cooked them in the oven for half an hour and they just dropped out when the cases were turned over. The Sleeve Gear replacement needed thumping to get in its housing and so did the Layshaft outer race. The inner race also needed warming before it would slide onto the Layshaft and then would not slide easiliy into its outer.
I am going to refill the box with Sythetic oil again as it appears to have worked OK, not caused any apprent damage and does not need changing as often as standard EP90.
What did you do about the…
What did you do about the loose bushes?, What did RGM say about them?.
Bush Bits
According to the blurb, sent with the kit, these two bushes are supposed to be loose both on the shaft and inside the respective gears. I have spoken with other reputed Norton Gearbox rebuilder who suggest that this is correct but the play should not be excessive. The more important chunks being the bush and bearings on the respective ends of the Layshaft. I guess the proof will be when roadtesting.
Comment on 6mm rod. Maybe…
Comment on 6mm rod. Maybe Norton were all set up with 1/4" drills. A 1/4" rod would jam unless they machined a clearance. Result = 6mm rod. So they procured 6mm ready manufactured. All makes perfect sense.
Mike.....your oil drip is almost certainly coming from the crankshaft oil seal. Possibly you replaced the old one with one of the cheap fakes on the market or the crankshaft damaged the new one.
For oil to get from an AMC gearbox to the Primary Cases, in serious quantities, is not easy due to the convoluted route it has to negotiate. It also would need something to pump the oil or oil vapour about which could be the clutch push rod but most unlikely if the correct item is inside the gearbox shaft.
I would suggest checking out your engine breather and the crankshaft oil seal as the more likely causes of your problem.
My 650 gets a little oil thrown into the primary cases but this is ok by me as it lubes the sides of the belt and helps to stop it grinding away on the pulley keepers.
