hi all new to the site ive picked up from an old a barn a 1958 domi that a want to rebuild i dont want to go stock i want to put my own take on it for me to ride i was looking for some advise on engine and clutch upgrades and whats availible
many thanks rob
Rebuild??
A couple of things to think about:
1. You posted this in the wrong site. A Domi is considered a heavy twin. The light twins are the Jubilee and Navigator.
2. Is the bike running now? If not, I would recommend that you get it running first so you have a good basis to work from.
rebuild
ya ive checked now ive put it on the wrong bit the engine was solid so it wouldnt run ive got it stripped now and found the pushrods are shot and the cam is worn the barrels look ok as do the pistons but i would like to mod the engine to get a bit more power and didnt know if there was a high lift cam or oversized pistons con rods ect
good advice
Hello Now here some Good advice From 50 years of experience of Norton twins Now you have a 62-year-old machine with limited parts So you must follow some rules these machines do not like to be overstressed in the engine department So do not overdo the mods now things you can do are machine out the cam tunnel to take an S2 Cam profile and RGM pushrods they make in stainless and flat type cam followers and gas follow the head with atlas valves mean a valve seat recut to fit then Bronze guilds with seals and terry springs and shims under the valve springs as for the bore Do not bore go over 40 oversize the next its to go back to standard as these barrels will not take big bores as they tend to weaken the barrel, next you need to check and large ends and main bearings and not to forget the OIL PUMP and the pressure release valve in the timing cover and do check and clean all oilways and rocker spindles and there wear and tear, and do get all the reciprocating parts in Balance, as for compression ratios goes 9:1 or ( 9:45:1 is about fine with lead subitues in the fuel, carburettors you need a good pair of amal 376/288 and 376/289 chopped mono bloc with a twin pull cables exhaust silencers a pair of Dunstall replicers with baffels will be fine spark pugs champoin N7BYC or N4 igntion spakrex D102 now go have fun yours Anna J
rebuild
wow thats alot of information thank you very much at the moment ive got the engine in pieces and at the vapor blasters are all the replacement parts available ie the cam and push rods? and would you think its best to keep the piston size stock the other thing was con rods would you stick to the originals ?
really appreciate the help
These are not really a…
These are not really a suitable motor to tune up ,they were known to be not bulletproof. The main suspect now would be con rods, No new original equipment rods have been availiable since the mid 1960's.You can now get aftermarket Rods . If you want to go fast I have a 150mph Honda to sell that's worth about 2K . But I'd rather you stuck with the Norton , just need to be realistic.
Con rods can be obtained of…
Con rods can be obtained of a better design from Thunder Race, and I think they may be using ARP nuts and bolts. All those parts were available when the dealers closed their doors in the 1970's and I was there when Taylor Mattersons closed, and they had a huge amount of Norton parts spread all over their main showroom floor.
Mods I made in the sixties
The 99 I had was clocked at 115 over a 30 miles straight. Apart from 50 pounds lighter, it had high comp pistons, dunstall exhausts, single carb and everything polished and in good tune. Miss the time with no speed limits.
rebuild
sounds good i cant wait to see what i can get out of the old girl
There are plenty of SH…
There are plenty of SH crankcases around if you blow up. The real difficulty is barrels .
If or when?
If used sensibly they can be…
If used sensibly they can be reliable, mine has not been properly to bits for 25 years, When built from bags of rusty bits and the seize sorted. The conrods are a bit like Russian Roulette, no idea what life they have led.And they do age too.
In reality Robert, my…
In reality Robert, my comment was based on the original request about tuning it. As you say, aluminium has a finite fatigue life and there are enough posts about it on here already.
As you said earlier, if you want to go fast, buy something more modern, or at least something where parts are plentiful/sensibly priced.
George
power comes from the Head
hello in days of old when we were racing Nortons Model 99SS the cylinder head reworked so it breathed better and oilways opened that bit so oil can flow around the rockers and down the pushrod tunnels to the cam followers and lube them and the cam and good oil pump is vital and main bearings is to along with vendervell shells bearings for the rods our club as some for these at a very good price, the camshaft I said an S2 Cam is a Dominator Road Cam as S3 And S4 can be a bit hot for a Road Bike, and a PW Cam is better for a Commando motor then a Model 99 but you will see over the ton even in standard mode its just the speed cams that will spoil things a bit, When fitting twin carbs you need new one as you never get them tuned right and new set of cables as well, to tune you start with left carb to right get the left running something like on one pot then move to right running something like on one pot then try both pots and then tune so she ticks over on both and revs with no blank spots, then try her out on a good back road where there, not much traffic, and give her a stort blast, you love it, have fun and stay safe yours anna j
rebuild
once again anna many many thanks for that regarding the clutch people have said go for a
bob newby belt drive have u any thoughts on this
cheers rob
Hi Anna
You are right in that airflow in/ exh gas out with minimal restriction is important for power, as is in cylinder air motion(swirl) influenced by the throat/valve seat detail. However the bottom end is equally so. The cam profiles dictate torque curve shape and hence power, and the engine speed equally so as power = torque x speed.
This is where a '99' has an issue. 50 years ago the alloy rods were new/nearly new. Now they are 50 years older. The rod shape was always a compromise and nowadays as Robert says it is a bit of 'russian roulette' as to how good the rods are. They always suffer greatest stress as you close the throttle from high rpm (mininal gas to compress), and this is where and why original rods will let go near the small end.
With new (uprated) rods and pistons, together with a decent oil pump the 99 could become a reliable higher power bike, but the argument is really whether it is worth the cost to achieve that or not.
As you often say, have fun.
George.
rebuild
some good points there george the thing is with this bike i can go a bit mad on it and instead of building the same old custom bikes for other people as ive done many many times with many different engines this will be the first norton ive ever owned or worked on and ive waited 50 years for it my grandad had a 88 in the 70s and i loved the sound and the bike.. it came as a package deal along with a spare 600 engine and two 57 square fours the deal was the fours would be put back to original condition and the norton i could have free rain over as long as i didnt cut the frame this was the sellers deal breakers and i had to sign up for it or he wouldnt let them go this went on for over a year so for me i would love to see what would be possible with the norton to get out of the engine its a back to my youth moment im based in derby and have some fantastic machine shops with some incredibly talented lads who are up for making some parts and i had a bit of a nasty lump removed from around my neck recently so i think why not!!!!
as ive said before all comments and replies are really apppreciated
cheers rob
rebuild
incidentally what is the top speed recorded for a dominator ????
I think the Dunstall was…
I think the Dunstall was timed at 136. If I was keen on building something really trick I would go for a 76degree overbored 88 motor with very light valve gear and bathtub chambers fed by D shaped ports.
rebuild
yep like the sound of that i really want to make the con rods valves and push rods from titanium and super finish the crank
If you want to make a hot…
If you want to make a hot Norton twin engine, start with a 650 or 750 engine. They are much stronger and have much more power potential, but vibrate. 500 engines are nice and smooth, but a '50s one is not a good basis for a fast engine. The later engines look pretty similar, but the detail design is very different, for lots of good reasons.
Don't bother over-boring your 500. They are not safe beyond +.040".
The rods are marginal, so if you want to rev an old engine, buy some new Thunder Engineering rods. They are well made and just go in. (FWIW the rod bolts thread into the main rod, rather than having a nut below). I bought a pair for my standard 500 - a previous owner bent the big end eyes by fitting -0.010" shells onto a standard un-ground crank (he confessed when I asked him how the rods got bent), and they got binned
Another good mod is a Commando oil pump, they have wider gears, so you get more oil pressure and faster scavenging. A hot early motor will have 0-5psi at idle, and maybe 40ish with some revs,so more is very good. Even standard, they wear well if the oil is kept clean and adequately fresh - I detected under 1/4 thou of wear on the drive side main on an engine with 80 or 90k miles on it. Fit an oil filter. But the 6-start pump gears on an early engine just cause trouble. You have to re-engineer the whole system.
The early inlet tract is restrictive, but don't go bonkers opening it out. The 650ss was ported 1 1/8", but worked better with the standard 1 1/16" carburetors. 70% of that area makes 1", and the standard inlet tract in the head is 15/16". The inlet valves are 1.4", big already, and there's no point in fitting 1.5" inlets intended for an Atlas. Those pots are 50% bigger. Similarly, the hot cams you mention were developed for racing 750 engines. A 500 will not make good use of them, and the high, rapid lift will just cause wear and drag. Anything beyond the '60s Dominator SS cam (the Commando SS cam is different and unsuitable) is a waste of time, and just wears things out and spoils low-down power.
Port your head gently, give it a really good 3 angle valve seat cut (it really helps gas flow when the valve is just off the seat), and lighten the valve gear. You can loose a lot of weight from the cam followers and rocker tips. Don't forget the pushrod ends of the rockers
What I am saying is that development for efficiiency reduces stress on what is not a strong motor. High tuning will make it go bang quickly. When you really know the motor and how you use and want to use the bike, think about what will give results. People have been there before.....
rebuild
hi paul again many good points i have to say theres alot of know how on this site so everyone that told me to join was right the two engines ive got are both 1957 600cc one is the twin carb model and the other is a single the twin carb model is stripped the cam pushrods and followers are trash so to the rings i havent stripped the crank yet or checked the rods but hopefully will get round to it at the weekend then ill put some pics up once again many thanks for all the comments
cheers rob
