Hi
I'm after a bit of advice, I'm stripping a 650ss engine and so far most bolts/nuts have been a nightmare to remove (I think threads have been subject to Loctite or something similar)
I'm now down to the worm gear on the crankshaft which I know is described as a left hand thread
I really cant shift this for love nor money. Can someone clarify that the removal is clockwise or anti clockwise as you look at the worm gear.
If I am doing it correctly , any ideas how to break the hold on the threads (heat spanner?)
mark
Yes Mark they can be very…
worm gear
hello, the worm gear should undo by rotating the gear with a box spanners they are clockwise to undo and then you need a gear pulling to remove the crankshaft main gear if do not have one our club as a special tools department, so contact Mr shoosmith, part department Yours Anna J
Worm gear threads
I'm confused (nothing new there!)
Howard says "clockwise to remove" and Anna says "anti-clockwise to undo"
Which is correct?
Worm Gear Removal Tips
Lock up the crankshaft using either method below........
1) If the barrels are already off..... use a thick steel rod through the small ends plus a wooden block over the crankcase mouth. Some strips of copper sheet inserted under the rod will help to prevent bruising of the conrod eyes. Old 15mm/0.5" water pipe is good for this.
or........2) If the barrel and head are still in situ then take out the Timing side spark plug and turn the crankshaft through to around 90* before the compression stroke. Then fill up the bore with coils of 8 to 10mm thick rope. Turn the crankshaft clockwise until it locks up because of the rope between the piston and head.
3) Heat the worm gear all round, preferably using a gas torch with a fine flame. Do not spend too much time on this other wise the heat will transfer through to the crankshaft and both will expand which will not help. Use a socket on the worm, turned by the longest or extended handle you can find. A car torque wrench works for me because it turns in the correct direction. Remember this is a left-hand thread so turn the handle over the top of the nut to the right to undo. This will be following the clock hands. eg clockwise when viewed from the Timing Side.
Thanks all for the prompt…
Thanks all for the prompt replies everyone
out of interest the engine is not in a chassis and I have been using a thick bar through the con rod eyes with wood underneath as support
Just tried applying some heat but still no joy and the direction is clockwise that I'm using.
I have had dommies many years ago and don't remember it being this hard. I think the 'phone a friend' option is the way forward so someone can hold the engine unit steady whilst I apply a longer bar. - cant wait to get to the pinion and trying to withdraw that!!!
By the way the engine is going into a café racer special I am building from sourced parts. The right hand rod on this engine on strip down inspection was just about to part company with the big end showing cracks and bits missing all around the alloy rod base. I reckon about 2mm up and down play so it should be a laugh once i split the cranks to see if the big end journals condition. - what fun
Mark
Have you got a friend who has..
An electric or pneumatic nut wrench? E.g. like the tyre shops use to undo wheel nuts?
You will need a big one, not one of the 1/4" drive ones available cheaply on Ebay.
They make it easier as the 'shocks' are so rapid you don't have to hold the engine so firmly, and you can concentrate on keeping the socket straight.
Worst case? Take the engine with the appropriate socket to a tyre shop?
Good luck, George.
Yes Mark they can be very tight. It's left-hand thread, so ccw to tighten and cw to remove. Get the oil pump out of the way and a good strong 1/2 inch drive hex socket on a strong long T-bar or breaker bar should suffice. Obviously you'll need to stop the engine crankshaft rotating so get it in a low gear and have some one stood on the rear brake pedal and give the bar a good shock with heavy soft metal mallet and Bob's your Uncle. Be careful if you use a twelve point socket they can soon slip off the worm hexagon. Good luck, Howard
