Hi, I have a good laydown gearbox. Can anyone tell me the length of the main-shaft I need for use with a Dominator please?
Thanks Keith
I think that the shaft you…
Out of interest, what’s the…
Out of interest, what’s the difference between them?
Cheers Dan
I have been told that the…
I have been told that the twin one is longer.
Trying to verify.
Single boxes have a shorter…
Single boxes have a shorter mainshaft, 8 5/8'' whilst twins use an 8 11/16'' mainshaft. These are interchangeable. As a result of this difference in length, the twin mainshaft protrudes from the sleeve gear showing a gap before the clutch splines, the single mainshaft does not.
Thanks Peter, That's…
Thanks Peter,
That's exactly what I wanted to know.
Brilliant thanks.
Keith
So the difference is…
So the difference is actually 1/16". I am amazed that it is so little..
I think that the shaft you need is the one stamped GT165. The one stamped GT175 is for singles.
