Gearbox drain plug
Could someone tell this newbie where it is please ? ('64 Navigator)
Ta.
Previously les_howard wrote:
Left side....part number: 67 on drawing below.....Les
Excellent! Thank you Les.
Terry
Hmm, still confused. Mine is a post 106838 gearbox with the oil level plug just below the inspection/filler plate, as in the attached pic. Still can't locate the drain!
g-box-oil-level-late-jpg
Yes, I have those instructions. Problem is I can't find the two plugs, let alone the smaller of the two!
Sorry Terry....someone hopefully will post a photo of it.....anyway at least I'm keeping your question at the top of the message list
Les
Les
Thanks! :)
Les
I think I've located the rascal (see pic) - nearer to the centreline of the bike than where I was looking, and lurking beneath a clotted mass of grass and oil!
gearbox-plug-3-jpg
Well done....I was going to suggest the likelihood of it being hidden under a mass of greasy road filth. You'll soon see if you have the right one when it's removed so put the drain pan there first before exploring.
Les
