Spraying
Whats the best way to spray a Jubilee frame. Can it be sprayed bolted up or is it best to dismantle and spray parts individually.
Can anyone recommend a paint spray in the Manchester area
John.
you will be far better off dismantling it, this way you can treat any corrosion between the mating surfaces there is bound to be some I would have thought bearing in mind how old these things are now, also if you spray across a bolted joint any flexing at this point will crack the paint film allowing moisture behind it, cannot help with any Manchester sprayer. kind regards
Anyone used Pete Priest for there paintwork, they are on Viaduct St Altrincham Cheshire. They seem to specialise in motorcycle paintwork. Any idea of their prices
John
Try, Farrout paint work Congleton, they did Jublee Triumph for the Factory.
Advertise in various magazines.
Jason, 01260 271221.
Good Luck with the build.
