Re: What are these holes for?
Two holes, at the bottom of the central channel section. Very convenient for mounting a remote oil filter, but what is their original purpose? Is this something to do with the centre stand stop?
Yes they're for the centre stand stop. A flap that sits at the base of the centre channel to keep muck from the rear of the engine is also bolted on there.
Thanks Maurice. Looking at the centre stand stop in the NOC shop it appears to be a steel 'spike' that bolts to the centre channel. Is it also supposed to have some kind of rubber buffer attached to it?
Terry
Ah, ignore my last. Just found it in the shop - 40p worth of rubber hose by the look of it!
Yes on all points! a mistake I made when fitting a remote filter was not taking the centre stand into account! I made my own stop, which mounts with countersunk screws to fit behind the filter.
Dan
Dan
Can you elaborate on why the centre stand was a problem Dan? I've got the filter mounting bracket from the club shop and I assume (tsk tsk) that it just bolts through the stop to the channel. Haven't got the stop yet so can't offer it up to check.
Terry
