In the parts listing for 1961/62 Models ES2, 50, 88, 99, 650, $ DeLuxe there is an air filter shown for "All Singles" Part number 18684
Has anyone ever seen one? I am guessing that they were popular in the mid-east because of the blowing sand, etc.
I cannot picture in my mind what it would look like and how it was fitted. There is a hole in the sheetmetal between the battery box and the oil tank but I am thinking that it could only be used on a twin. On then singles the carb is mounted splayed and the hole will not line up.
Photos or drawings would be appreciated.
Mike Sullivan in San Francisco
Hello Mike, I have a proto…
BTW, rather than run open,…
BTW, rather than run open, you can buy a short mesh bellmouth from Amal.
Hi Mike I would also be in…
Hi Mike
I would also be interested in seeing a picture of the air filter to fit to my 1960 slimline model 50......I was even thinking of re-welding the inlet stub to make it line up with the hole between the oil tank and battery cover to enable a filter to be fitted, but possibly this is a bit drastic! any sugestions would assist. I already have a short belmouth with mesh fitted.
Regards John O
When I still had my slimli…
When I still had my slimline ES2 I welded up a removable extension to the intake that allowed the std carb to sit at 90deg to the motor. I got some s/steel flanges laser cut and used dairy quality piping (1.6mm wall thickness) in s/s to get the required bend. This allowed me to use a pancake airfilter. One could have used a cone K&N also. No ill effects on the fuelling here in the warm colonies.
Hello some one as removed…
Hello some one as removed my early posting with information on Amal air fitters the parts Number on the Pancake air filter is type 96 for amal 376 amal 389 single carburettor fitting this is from my big AMAL part manual See www.Amal.co.uk your anna j
Hello Mike,
I have a proto type made by Amal, it is the pancake type but I think less than one inch across. I obtained it many years ago from Martin Bratby.
I can tell you that it will fit, just, on the singles so it will easily fit on a twin, though I never got around to trying it on a twin..
Last year, I was going to have it made in stainless but couldn't find it and not had time to search since. When I do find the filter I'll post a picture with measurements on here. But the short answer is that such a filter does exist.
